Home > Tdi > Transfer box diff fault
Tomo44
United Kingdom 1996 Defender 90 2.5 TD CSW Epsom Green
Had vibration from drive train, took the front drive shaft off to check front end, found I had no drive to the back wheels even with diff lock on, hand break still works, could it be diff fault or transfer box?
Post #901949 7th May 2021 9:52pm
Does the rear prop shaft turn when trying to drive? if yes, then the fault lies with the back axle (diff, half shafts, drive flanges). If no, then it's most likely the transfer box.
Thinking about it a bit more, the fact that the handbrake works suggests that the fault is in the transfer box, too. Darren
Post #901989 8th May 2021 11:30am
Tomo44
I thought that but then if the handbreak locks the back axel it proves nothing as the back wheels will be locked if it's the transfer box and the transfer box if it's the rear diff, further investigation has suggested the diff lock isn't engaging, link looks good so changing the transmission fluid to see if any metal appears
Post #901995 8th May 2021 11:41am
landy andy
You drive (without diff lock) your Defender and get a vibration. Then you take the front prop off to check it. But now have no drive to the rear, and non operating diff lock.
This can’t happen. If you have no drive to rear, and non operating centre diff lock you wouldn’t be able to drive the vehicle.
Post #902001 8th May 2021 12:07pm
Tomo44
Yes but I didn't know the diff lock wasn't engaging, addressing this problem now
Post #902016 8th May 2021 1:45pm
Dinnu
The diff lock switch is acting on the locking hub, so assuming that the wiring is good and dash light is also good, the light would come on when it is truly locked.
The diff lock lever is right above the front output flange. Easiest access is through the middle hatch in the seatbox, under the cubby box or middle seat.
I am assuming you remove the front prop shaft to isolate the vibration issue. Correct?
Propshafts have balancing plates welded to them, and if they fall off, they can vibrate. Check also that the crosses are in good condition. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #902017 8th May 2021 2:01pm
Tomo44
Prop shafts both have plates both and are sound, still can't get the diff light on, I've checked I have drive to both shafts and I do, sitting still both torq up when power applied, when the rain stops, tomorrow, I shall remove the switch and test it after that I am lost for a solution to the diff lock issue and none the wiser on my vibration issue
Cheers for the help
Post #902023 8th May 2021 2:09pm
landy andy
You’ve removed the front prop, and now the trans box is spinning the easiest route, the front drive flange, as you’ve removed the prop. So no diff or axle problems, just need to sort the diff lock. Take the covers off from inside the defender and expose the top of the trans case and you will see the operation rod. Easy to remove cover and check that grub screw that operates inside shaft is tight and moving shaft.
Post #902024 8th May 2021 2:14pm
Dinnu
^^^ IIRC grub screw is only on the high/low shaft.
The cover for the diff lock is the rounded one with 3 bolts. It does not take a gasket as it seals with an O ring. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #902035 8th May 2021 3:12pm
jst
Just wind out the diff lock switch a few threads, it's stopping the lock engaging. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #902078 8th May 2021 9:50pm
