Home > Tdi > Stiff Clutch Pedal after driving in traffic |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 820 |
Interested to hear any replies to this.
My 300tdi has always had a light clutch, even after a replacement was fitted (including new fork) But pedal feel has always been variable when driving any distance. A bit confusing because it can be rock steady predictable for a 200 mile trip, or feel different every 10 miles to the next during a similar journey. Always works but just doesn't always feel 'right'? |
8th May 2021 10:15pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2656 |
Clutch pedal bushes dry/sticky would be my guess, but it could also be the thrust bearing slide or the clutch fork pivot point. Wear or lack of lubrication in any of these can lead to a stiff or inconsistent pedal.
9th May 2021 6:52am |
Silver Back Member Since: 11 Jun 2015 Location: Lincolnshire Posts: 407 |
One other potential cause could be the flexible hoses getting hot.
I had a Lotus Elise which had a tendency to have the same issue. In this case it was the original flexible hose passing alongside the radiator hose. Replacement with a stainless braided hose resolved the issue. Obviously a very different lay out to the Defender but might be worth check if any heat / hot gases are somehow affecting the flexible to the slave cylinder. Hope you get it sorted. |
9th May 2021 11:20am |
Classic110 Member Since: 14 Mar 2021 Location: East Yorkshire & Hertfordshire Posts: 25 |
Thank you all for your comments and guidance. Just inspected the Flexi Pipe and it does look a little sad. So will change this and see if it improves the feel.
9th May 2021 11:58am |
