Home > Tdi > Stiff Clutch Pedal after driving in traffic
Classic110
Recently my 300tdi 110 clutch pedal has developed a tendancy to become a lot stiffer when driving in stop start traffic. A complete new clutch assembly, updated fork, together with new master and slave cylinders were changed about 8000 miles ago. When it is then left for an hour or so it goes back to normal!! Any thoughts?
Post #901214 3rd May 2021 5:56pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Interested to hear any replies to this.
My 300tdi has always had a light clutch, even after a replacement was fitted (including new fork) But pedal feel has always been variable when driving any distance. A bit confusing because it can be rock steady predictable for a 200 mile trip, or feel different every 10 miles to the next during a similar journey.
Always works but just doesn't always feel 'right'?
Post #902084 8th May 2021 11:15pm
Retroanaconda
Clutch pedal bushes dry/sticky would be my guess, but it could also be the thrust bearing slide or the clutch fork pivot point. Wear or lack of lubrication in any of these can lead to a stiff or inconsistent pedal.
Post #902096 9th May 2021 7:52am
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
One other potential cause could be the flexible hoses getting hot.
I had a Lotus Elise which had a tendency to have the same issue. In this case it was the original flexible hose passing alongside the radiator hose. Replacement with a stainless braided hose resolved the issue.
Obviously a very different lay out to the Defender but might be worth check if any heat / hot gases are somehow affecting the flexible to the slave cylinder.
Hope you get it sorted.
Post #902143 9th May 2021 12:20pm
Classic110
Thank you all for your comments and guidance. Just inspected the Flexi Pipe and it does look a little sad. So will change this and see if it improves the feel.
Post #902146 9th May 2021 12:58pm
