Home > Tdi > BULKHEAD REMOVAL BAR
Francisco
Brazil 2000 Defender 90 300 Tdi CSW Chawton White
I have a DEfender and was removed the plate that is behind the driver's seat. To compensate I have to put the tubular bar.
The model used in my country is the model in the pictures. But I don't know what the code is. I do not want to indicate an answer but I think the correct model is STC4589.
What I want to know is if someone can tell me what is the correct code of the tubular bar from the pictures. I will put some diagrams that might help.
Here are the diagrams I found:
https://www.lrworkshop.com/pt/diagrams/lan...ts_53630#1
https://www.lrworkshop.com/pt/diagrams/lan...r_52754#11
It could also be
ALR5556
https://www.lrworkshop.com/pt/diagr...body...r_52795#11
https://www.lrworkshop.com/pt/diagr...remi...r_53693#11
Post #900810 1st May 2021 3:42am
Dinnu
Have installed DA1810 (google search gives a lot of hits). Was not a perfect fit as one of the brackets was manufactured incorrectly, but with some modifications it was done. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #900813 1st May 2021 6:10am
