Home > Td5 > Truck runs better after battery died - discuss.. |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 626 |
Not adaptations, but possibly some engine limp mode after some faults. With battery out, faults are cleared and so the limp mode. Both can return later. Partly faulty MAF of sticking turbo wastegate are not uncommon for TD5. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
15th Apr 2021 1:51pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 942 |
As above... faults cleared due to now voltage and runs better. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
18th Apr 2021 2:46am |
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 |
Confirm the suspicion by plugging it up to Nanocom at the point where you think its running at its lower power, see what faults you have. Insta: @thebenjordan4x4
18th Apr 2021 7:37am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20472 |
A duff battery will cause the alternator to constantly keep charging too which will add more constant load to the motor all be it little.
On my old battery I was getting around 14.4v charging now it’s around 14.7 / 14.8v with the battery changed. I’m not sure if the TD5 alternator is the same design as the TDCi but when up to voltage on the Puma it free spools which means no load / little load on the engine. The added load is going to reduce performance in a small amount, very similar as to when the AC compressor is active if fitted. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
18th Apr 2021 1:42pm |
Unfortunately no the TD5 alternator is a simple affair albeit with the vacuum pump sat on the front of it and it is loading the engine constantly. So is the Puma alternator on a clutch type mech like an AC pump?
Having just replaced two 10+ year old batteries I can attest to the difference the new ones make as it revs a little lower at idle, so less voltage required and so less load on the engine. |
21st Apr 2021 11:39am |
