Home > Td5 > exhaust smell
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
exhaust smell
Hi. My 110 2002 defender Td5 - 310.000 km do smell quite a lot like a diesel....I do not ever mount my trailer with engine running🤢 eventhoughh it is warm... There is almost no smoke at cold start and when running - does not use much oil ( 1/2 a litre pr 5.000 km)
I was wondering if my cat is done - I think it is the original - and if a working cat reduces the smell?? Also looked in to mounting a DPF instead of the cat ( I have the P15 engine) if that would reduce the smell.
People are getting more and more negative about exhaust fumes so if anyone knows about the above it would be greatly appreciated - I know a DPF is pricey but I plan to keep my car as long as possible.
Regards
Christian 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #895841 4th Apr 2021 10:01am
Dinnu
I see 2 problems:
1. How will the ecu know that a regen is required? I do not think there are many who went down this route and trigger anyone to make a special map for Td5 with dpf combo.
2. Probably on the books it will still be a Euro3. Just think ahead to when the EU starts making tighter restrictions on emissions (environmental tax).
Good Td5s command a good price, because the purists says it is the last and best of the original Defender. Your other option maybe to trade it with a 2.2. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #895843 4th Apr 2021 10:49am
CRJ
Hi. The DPF that is approved for a TD5 - in Denmark and Germany i Think - is a open type DPF which does not require regeneration. It puts the car in Euro4.. it is pretty expensive about 1.400 gbp - but then you are allowed in the Big cities - at least for a while.
But does the dpf help reducing the smell? Or more than a working cat?
Regards
Puma 130 - 08- sold
110 CC 2003
Post #895845 4th Apr 2021 11:00am
Dinnu
Good to hear that for Denmark. Does not apply where I live.
What I can say is that we have 4 defenders in the family. The 2.4 and Td5 smell terrible when they are started to take out of the garage. My 2.2 do not even notice that a car was started. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #895851 4th Apr 2021 11:26am
landy andy
The cat makes a massive difference to the smell. So perhaps yours is knackered.
Post #895912 4th Apr 2021 7:18pm
CRJ
Great - a friend of mine have an almost new one - I Will try that .... and take a Big 🐽🐽 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
110 CC 2003
Post #895966 5th Apr 2021 9:15am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
yup, that stuff animal in there will make it smell different.
if it's working, it should smell somewhat nicer than raw exhaust. I'm assuming that the fuelling of the engine is correct as many have been mucked about with.
However, without the cat, you also have performance gains when mapped correctly and the passenger side is cooler on a long drive.
decisions, decisions. The defender has migrated, leaving the owner behind.
Post #896147 6th Apr 2021 10:23am
