![]() | Home > Td5 > exhaust smell |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3506 ![]() ![]() ![]() |
I see 2 problems:
1. How will the ecu know that a regen is required? I do not think there are many who went down this route and trigger anyone to make a special map for Td5 with dpf combo. 2. Probably on the books it will still be a Euro3. Just think ahead to when the EU starts making tighter restrictions on emissions (environmental tax). Good Td5s command a good price, because the purists says it is the last and best of the original Defender. Your other option maybe to trade it with a 2.2. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253 ![]() ![]() ![]() |
Hi. The DPF that is approved for a TD5 - in Denmark and Germany i Think - is a open type DPF which does not require regeneration. It puts the car in Euro4.. it is pretty expensive about 1.400 gbp - but then you are allowed in the Big cities - at least for a while.
But does the dpf help reducing the smell? Or more than a working cat? Regards Christian 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
Good to hear that for Denmark. Does not apply where I live.
What I can say is that we have 4 defenders in the family. The 2.4 and Td5 smell terrible when they are started to take out of the garage. My 2.2 do not even notice that a car was started. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5846 ![]() ![]() |
The cat makes a massive difference to the smell. So perhaps yours is knackered.
Great - a friend of mine have an almost new one - I Will try that .... and take a Big 🐽🐽 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
yup, that stuff animal in there will make it smell different.
if it's working, it should smell somewhat nicer than raw exhaust. I'm assuming that the fuelling of the engine is correct as many have been mucked about with. However, without the cat, you also have performance gains when mapped correctly and the passenger side is cooler on a long drive. decisions, decisions. The defender has migrated, leaving the owner behind. |
