Home > Puma (Tdci) > Is some lowlife trying to steal it?
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
2011 model 2.4 Puma 110 XS
Three times over the past 4 days, in locations up to 150 miles apart, the alarm has sounded randomly from 2 mins. to 4 hours after locking the vehicle. That's 3 times out of around 10 "lockings"
In each case the Puma had unlocked itself causing(?) the alarm to sound.
Anyone else had this? If so was it an alarm fault or something more sinister?
Please PM if you are not comfortable with discussing this openly.
Thanks
Post #895636 2nd Apr 2021 7:18pm
landy andy
I had a lazy drivers door actuator years ago that would unlock the car and sound the alarm.
Post #895644 2nd Apr 2021 7:36pm
shropshiredefender
Thanks I'll check it. Just because you're offended doesn't mean you're right.
Post #895647 2nd Apr 2021 7:49pm
landy andy
Took me ages to find it. Would always do it when I was not about. New unit sorted it
Post #895648 2nd Apr 2021 8:05pm
jieming
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Is it just unlocking or is the dashboard also lighting up like a Christmas tree? If so it could be a faulty earth. There's a large earth cable located on the passenger side down by the gearbox. Sometimes if you've been through lots of water it can play up. Mine just needs a wiggle and it solved the problem.
Post #895899 4th Apr 2021 5:06pm
