![]() | Home > Puma (Tdci) > No flashing from indicators on locking |
trailbear Member Since: 14 Sep 2016 Location: Scotland Posts: 405 ![]() ![]() |
You never know, it might work, I’ll give it a go.
Thanks |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2259 ![]() ![]() |
Have a look halfway down this thread of posts https://www.defender2.net/forum/topic71987...p;start=15
Yellow110 states “I had this same issue and it drove me mad trying to solve it (but I did in the end). Having the indicators flash when arming/disarming is actually a behaviour that can be toggled on or off just by multiple presses of the key fob when the drivers door is open. My ex used to accidentally do it all the time and I couldn’t work out why the indicators never flashed only after she had been driving it. From memory I think you have to have the door open and press the unlock button twice. The indicators will then do some sort of long flash to confirm the mode has been changed. Hope this helps.” |
Before trying anything else contact black box solutions, highlight what you have done and the resulting issues and get their advice on what to do via the nanocom. Also go on their forum and see if there are any posts or guides on the same issue.
These later ALM units do seem to be flaky! |
Okay, will drop them an e mail and see if they can help.
