Home > Puma (Tdci) > Engine Power Cutting
nickhodgson
Hi
Is it normal for the 2.4 ddci engine to cut power to the engine when you apply the brakes and accelerator at the same time. Like if you wanted to remove some of the mud from the brakes?
Thanks
Nick 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #895111 31st Mar 2021 3:44pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
I know BMW’s from the e46 model onwards do that (stops heal and toe 😢) but if you disconnect the MAF then no problem on accelerator and brake. Maybe the defender has the same, not tried heal and toeing in the defender yet 😂😂 Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #895112 31st Mar 2021 3:48pm
Re: Engine Power Cutting
nickhodgson wrote:
Hi
Thanks
Nick
Yes, entirely normal on the Puma, and in fact normal on most drive-by-wire vehicles. it's also very annoying if you need to dry the brakes, or keep them dry when fording by keeping light pressure on the pedal.
(It is also a subject I have vented about several times before on this forum!)
Post #895132 31st Mar 2021 5:06pm
skidrov
Australia 2010 Defender 110 Puma 2.4 SW Fuji White
You can heel/toe in a Puma - standard daily practice. It's a driveline preservation technique as much as a performance technique.
Post #895252 1st Apr 2021 4:43am
Race.it
So good to know it’s possible, I know it’s good for the power train etc just on more modern cars I normally hit an issue when you press the brake pedal the accelerator basically is useless. Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #895270 1st Apr 2021 7:36am
nickhodgson
Funny I thought the car was broken........this is the third 2.4 Puma that I have had and had not noticed any issue on the previous two Pumas. Very Happy 1995 300tdi Defender 90 P/UP
Post #895322 1st Apr 2021 1:00pm
Perhaps the last two were broken! Very Happy
Post #895363 1st Apr 2021 3:10pm
