Home > Puma (Tdci) > paranoid about factory fill oils |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 |
Today I replaced the transfer oil.
Everything went fine, very few metal dust attached to the drain plug magnet. Next week I will change the transmission oil. Is the drain plug also magnetic ? |
3rd Sep 2011 7:21pm |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
yes it is - and I'll bet there will be plenty of metallic gunge stuck to it - more than on the Tbox plug anyway !
3rd Sep 2011 7:40pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2431 |
I`m not sure it is. At least the MY07 it is not. Puma 110" SW
3rd Sep 2011 8:01pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
Diffs Magnetic yes, Transfer box no...you can buy a magnetic one Mike
3rd Sep 2011 8:41pm |
MY11 gearbox drain plug is magnetic - well it is on mine anyway. There was quite a mound of tiny metal shards stuck to it when I changed the oil a couple of weeks ago - like a little sculpture it was
3rd Sep 2011 9:11pm |
Gearbox is as is the diffs, just not the Transfer box Mike |
3rd Sep 2011 9:37pm |
Carl l Member Since: 03 Sep 2011 Location: Northern Hemisphere Posts: 9 |
One sheep man? Current: 2011 Shogun SWB 3.2td 200hp stock, Auto (my knees are shot), but this is a great farm truck Prev: a Disco (got old), a Range Rover (too ostentatious) and a Defender (knees). Tractor: 1993 Ford 8830, 6.6td, 180hp at PTO stock |
7th Sep 2011 2:45pm |
I found this plug that I believe is the MT82 fill plug. Is the same type and size of the drain plug.
Click image to enlarge The image was taken looking front to rear. Is this the right plug ? I read somewhere that the fill plug is different from the drain plug. Anyway, I flushed about 2.7 liters of oil, I'm now waiting your answer about the fill plug. |
8th Sep 2011 6:17am |
That`s the one and both are the same. Puma 110" SW
8th Sep 2011 9:02am |
Thanks for the information! I replaced both transmission and gear oil.
Next week I will install magnetic plugs in the front and rear diffs. |
10th Sep 2011 4:17am |
