Home > Tdi > Possible 300tdi engine failure |
Smyles_ Member Since: 25 Aug 2018 Location: Copenhagen Posts: 517 |
Is the fuel pump priming? Stuart
Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
28th Mar 2021 11:22pm |
Tommybahama32 Member Since: 11 Sep 2017 Location: cheshire Posts: 31 |
First thing I would be checking is the stop solenoid. Check the live feed to it. I had a similar issue the multi block connector had live going in to it but no live coming out due to a corroded terminal.
29th Mar 2021 4:29am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2656 |
Then remove the oil filler cap and check the valve train moves when it’s turned over. If not then the timing belt has gone.
29th Mar 2021 6:31am |
Jeebs Member Since: 23 Oct 2015 Location: North West Posts: 197 |
I got it recovered by a mate and it’s currently in his workshop.
I’d doubt it was the timing belt, as that was done less than 5k miles ago. Electrical gremlins or fuelling issues were my first thoughts, but it’s hard to check at the side of the motorway, soaking wet and miserable 😀 |
29th Mar 2021 8:17am |
Bottom half of the engine turns, top half doesn’t.
Rebuild, new engine or sell it. |
29th Mar 2021 12:31pm |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 |
oh so that was the timing belt. You'll need the head sorted now everything else should be ok. The pushrods and valvle guides, valves etc might be all scrap now
29th Mar 2021 12:54pm |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 933 |
New one on FB. May help?
https://www.facebook.com/groups/1387967266...7775587388 |
29th Mar 2021 2:16pm |
The thing that worries me is the timing belt was redone at 201k, it’s only done 6k since then. Surely it can’t be belt failure, considering they’re meant to be good for 70k?
Cheers Bodstruck 👍 |
29th Mar 2021 2:39pm |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 532 |
Who did Timing belt change was tensioner done at same time, What make of belt, I only use genuine or Dayco personally.
29th Mar 2021 4:03pm |
It was done by a friend of mine who’s a mechanic, he’s got a lot of experience with LR stuff.
It was a Bearmach kit with a new tensioner and bits, including a Dayco belt. |
29th Mar 2021 4:10pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1865 |
Sorry to hear, but personally, I would not sell as is, so rebuild or renew engine depending on diagnosis would be my advice Rob 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
29th Mar 2021 4:26pm |
Recent replacement is no guarantee of longevity - sadly there are many poor quality parts around these days. It’s sometimes a struggle to find properly branded belt tensioners for example.
Belt change, new push rods, check cam followers and valve gear for damage (unlikely) and you’re back up and running. |
29th Mar 2021 5:26pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2248 |
^^^^ as James said above, an afternoon's work will have you back on the road. No need for new engines or rebuilds.
29th Mar 2021 6:19pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 626 |
Does the mechanic really know what he is doing? Does he have the correct Torqueleader gauge for setting the tensioner? Is the injector pump fitted with the later bracket to postion the pump correctly to stop it running out of line? |
30th Mar 2021 2:37am |
