Home > Tdi > Possible 300tdi engine failure
Jeebs
United Kingdom 1995 Defender 90 300 Tdi HT Barolo Black
Driving on the m62 today, uphill section towards Manchester from Junction 23 and all of a sudden I had a complete loss of power and the engine cut out. No big bang or anything noisy, just heard all the drive train slacken off as the engine cut out.
I managed to get across to the shoulder and tried to see what the problem was, no visible fluids leaking, nothing to suggest turbo failure, everything appeared in working order but clearly isn’t.
Engine will turn over on the starter but won’t kick into life.
It’s a 16L 300tdi, 207k on the clock, but well serviced and looked after, any ideas would be appreciated!
Post #894599 28th Mar 2021 11:16pm
Smyles_
Denmark
Is the fuel pump priming? Stuart
Cummins 130 Build Thread
Instagram
58 130 Double Cab HCPU - Cairns Blue
04 110 Double Cab - Black (gone)
07 Audi RS4 Avant - Silver
Post #894600 28th Mar 2021 11:22pm
Tommybahama32
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
First thing I would be checking is the stop solenoid. Check the live feed to it. I had a similar issue the multi block connector had live going in to it but no live coming out due to a corroded terminal.
Post #894606 29th Mar 2021 4:29am
Retroanaconda
Then remove the oil filler cap and check the valve train moves when it’s turned over. If not then the timing belt has gone.
Post #894608 29th Mar 2021 6:31am
Jeebs
I got it recovered by a mate and it’s currently in his workshop.
I’d doubt it was the timing belt, as that was done less than 5k miles ago.
Electrical gremlins or fuelling issues were my first thoughts, but it’s hard to check at the side of the motorway, soaking wet and miserable 😀
Post #894623 29th Mar 2021 8:17am
Jeebs
Bottom half of the engine turns, top half doesn’t.
Rebuild, new engine or sell it.
Post #894667 29th Mar 2021 12:31pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
oh so that was the timing belt. You'll need the head sorted now everything else should be ok. The pushrods and valvle guides, valves etc might be all scrap now Crying or Very sad
Post #894673 29th Mar 2021 12:54pm
bodstruck
Post #894684 29th Mar 2021 2:16pm
Jeebs
The thing that worries me is the timing belt was redone at 201k, it’s only done 6k since then. Surely it can’t be belt failure, considering they’re meant to be good for 70k?
Cheers Bodstruck 👍
Post #894688 29th Mar 2021 2:39pm
htb2
Wales
Who did Timing belt change was tensioner done at same time, What make of belt, I only use genuine or Dayco personally.
Post #894709 29th Mar 2021 4:03pm
Jeebs
It was done by a friend of mine who’s a mechanic, he’s got a lot of experience with LR stuff.
It was a Bearmach kit with a new tensioner and bits, including a Dayco belt.
Post #894714 29th Mar 2021 4:10pm
CarMan
Sorry to hear, but personally, I would not sell as is, so rebuild or renew engine depending on diagnosis would be my advice Thumbs Up Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #894720 29th Mar 2021 4:26pm
Retroanaconda
Recent replacement is no guarantee of longevity - sadly there are many poor quality parts around these days. It’s sometimes a struggle to find properly branded belt tensioners for example.
Belt change, new push rods, check cam followers and valve gear for damage (unlikely) and you’re back up and running.
Post #894731 29th Mar 2021 5:26pm
Mo Murphy
^^^^ as James said above, an afternoon's work will have you back on the road. No need for new engines or rebuilds.
50 Shades of Pennine Grey
Post #894747 29th Mar 2021 6:19pm
Oldowner
Does the mechanic really know what he is doing? Does he have the correct Torqueleader gauge for setting the tensioner? Is the injector pump fitted with the later bracket to postion the pump correctly to stop it running out of line?
Post #894834 30th Mar 2021 2:37am
