Home > Off Topic > 2 cylinder diesel engine advice
Page 2 of 2 <12
Dinnu
Good to hear that Tomotomo.
Too much diesel on the cylinder bore is not helping on ring wear, but the first couple of cranks before a diesel engine fire up, the diesel is actually helping the rings and valves to make a better seal.
Probably in your case, that amount of diesel, or the viscosity of the diesel was not enough to improve the sealing and get the required compression and hence temperatures to spring into life.
Compression test kit? First make sure that the compression kit that you are getting is for a diesel engine. Diesel engines are capable of huge amount of compression, that a kit designed for petrol engines will become permanently damaged.
For diesel engines, a leak down test will probably give you more useful information on where the problem is. If you have a small compressor, you may try to get an adaptor and supply air pressure into the cylinders, and then listen (or feel) where the air is leaking most.. crankcase means rings, exhaust means echaust valve and intake means intake valve is a problem.
Cannot find a rebuild kit for the engine? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #894998 30th Mar 2021 8:40pm
Tomotomo
Thanks for your help.
I have got a diesel compression kit being delivered. It comes with some adaptors so I will try the compressor leakdown and see if I can pinpoint the loss of compression further.
I am.going to try and start it from cold tomorrow and if it fails to start I will know I have to get on with a replacement or rebuild.
I have never rebuilt an engine before. Maybe I should learn.
Thanks again Thumbs Up
Post #895006 30th Mar 2021 9:37pm
Dinnu
Below page specifies the compression pressures.
https://www.manualslib.com/manual/1154027/...ml?page=76 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #895008 30th Mar 2021 9:57pm
Tomotomo
That's Great thanks! I will post my findings Thumbs Up
Post #895011 30th Mar 2021 10:07pm
Tomotomo wrote:
Do we think that all my cranking and subsequently all that diesel spraying into cylinders could have washed the residual oil away on the bores causing the piston rings to loose their sealing abilities?
No, it is most likely that the engine is excessively worn.
Post #895013 30th Mar 2021 10:17pm
Tomotomo
Ok thanks blackwolf.
It started up this morning right away from cold?! As normal !
Post #895042 31st Mar 2021 9:10am
Dinnu
Was the engine sitting idle for a long period of time? Perhaps outside?
If yes, it could have simply been a sticking ring, or a little corrosion on the valve/valve seat?
The fewer the cylinders in an engine the more it needs to be in top condition for it to start easily. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #895052 31st Mar 2021 10:13am
dorsetsmith
Drain coolant removing head check valve/valve seat and also with piston down check liners for no scoring rust or glazing and no lip at the top of the liner
If its ok new head gasket set reassemble top end
Post #895057 31st Mar 2021 10:44am
Tomotomo
I guess the machine sat for 3 weeks. Maybe I knocked a small bit of crud into cylinder when doing glowplugs or had injectors out?
Anyway turns out my cheap compression kit adaptor doesn't fit. I am going to use the dumper this weekend and see how it behaves.
Dorsetsmith that is probably exactly what I should do but I have quite a lot of work on at the mo. I think I will keep my eye out for a spare engine and in carry on for now.
Thanks all, a lot of knowledge on this forum Thumbs Up
Post #895505 2nd Apr 2021 8:52am
Page 2 of 2 <12
