Home > Puma (Tdci) > New Engine Needed? |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3431 |
The only thing I can recommend you is yes, find another garage.
If you want to check for heavy berating, it is quite simple to do, just remove the oil filler cap when engine is running and is at temperature. You might get some vapour of oil, small amount is normal. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
16th Mar 2021 10:55am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5736 |
Where did you take your defender for this opinion?
16th Mar 2021 11:11am |
Brooksy Member Since: 28 Nov 2020 Location: London/Bedfordhire Posts: 8 |
have used them before on a previous vehicle so thought they would be good - they just won't do any engine work sadly so need to find a suitable chap that knows his way around the 2.2 transit engine!
16th Mar 2021 11:18am |
16th Mar 2021 11:31am |
Looks like a decent garage.
What’s the full story/history of the Defender. Is it mega mileage? Why did you take it to them? I’m surprised they are only offering a full engine option and no others For complete engines Turners have a very good reputation in Defender circles. https://www.turnerengineering.co.uk/lr0553...2x23282392 |
Only had it for 5 months, previous owners were Land Rover Ripon in Yorkshire and have their internal invoices as proof it was serviced regularly.
130k miles, so not nothing, but a lot considering the age. Took it in for the oil leak |
16th Mar 2021 11:35am |
At 5 months ownership what is your warranty situation?
It all sounds very dubious to me. Definitely need some more opinions on it. Especially if it actually drives ok. |
16th Mar 2021 11:38am |
Private sale - no warranty.
Yeah just looking for good recommendations! |
16th Mar 2021 11:41am |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 |
Sounds like a piston ring issue, probably get away with a good engine rebuild
Try changing the crank case breathers first Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
16th Mar 2021 11:55am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2302 |
"Breathing heavy... New engine" Wow. Glad you're looking to take it elsewhere.
Do you have any photos of where the oil leak is coming from? We may be able to offer some advice > 110 XS Double Cab |
16th Mar 2021 11:59am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7907 |
Speak with forum sponsor CSK at Buntingford, not too far from you. James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
16th Mar 2021 12:31pm |
No photos sadly, have tried having a good peer in, but its just not clear. |
16th Mar 2021 12:41pm |
Thanks, will give them a ring! |
16th Mar 2021 12:48pm |
Actually not true Click image to enlarge Click image to enlarge Click image to enlarge |
16th Mar 2021 12:54pm |
