Home > In Car Electronics > Puma 2015 fuse help |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 299 |
Have a look at the under dash fuse box, fuse ID 43 (F44) should be 5amp.
10th Mar 2021 8:55pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2158 |
?? Only goes to F40 and have checked all as best as I can with no joy........
Presume there is a fuse in the back of the head unit?? |
10th Mar 2021 9:25pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2039 |
Is the clock and interior light working ? If they are then it shouldn’t be the fuse
as they are on the same fuse as the radio. |
10th Mar 2021 10:02pm |
That was what I thought and yes all working as they should.......
10th Mar 2021 10:03pm |
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 354 |
Ignore this!
10th Mar 2021 10:05pm |
According to my Haynes manual F27
10th Mar 2021 10:06pm |
Just thought that the truck was in for Warranty paint work on the bulkhead / screen surround and the lower windscreen foam seal
Guessing they may have needed to strip the dash to some degree to gain access?? If so then they simply haven't plugged it back in?? |
10th Mar 2021 10:10pm |
Think it’s fuse 30 on 2.4 and 29 on 2.2 but not 100% certain.
If you have had work done then maybe you need to enter the radio code to get it working again? |
It has no power or illumination at all, nothing to do with even getting to a code stage......
10th Mar 2021 10:11pm |
Click image to enlarge |
10th Mar 2021 10:12pm |
Look 2 down under your orange markings, says fuse 29.
10th Mar 2021 10:15pm |
90 Dreamer, looks like centre dash panel out then to see the back of the radio.
10th Mar 2021 10:17pm |
Is the clock working?
10th Mar 2021 10:24pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1076 |
F27 5A is ignition switched
F29 15A is permanent live (also connected to clock and OBD socket) |
10th Mar 2021 10:31pm |
