Home > eBay & Bargain Spots > Fox shocks 2 inch lift.
Page 2 of 4 <1234>
Likeomg
jonny wrote:
I'm sorely tempted by these as I've got a 2" lift already with some fairly old De Carbon shocks that are probably past their best...
I've read some reviews that suggest that these can be a bit 'harsh' on road / unloaded compared to some of the other less off road biased alternatives - anyone have some real world feedback (Likeomg?)
I did try and post a response earlier but corporate wifi keeps kicking me out???? new ship what to say..
Like above, think the damping is excellent, road use have them 3 clicks from open, unladen 90, turn them all the way up for towing the boat / ifor / anything heavy (still to test them completely loaded with the 3.5t Ifor) but the boat when im moving it is probably 2.5-3t as i take a bit of kit with me.
Tried them on some pretty rough 'gravel' roads up in Scotland at a pretty quick pace and was very impressed with the damping and control basically a mini dakar truck is how i'd describe the feel in comparison to a standard def, yes it rolls more than the previous bilstein setup but i also changed springs when i did the shocks from 'sport' to 'comfort'
can't really imagine a better setup for my usage and would recommend to all.
Post #888923 3rd Mar 2021 11:55pm
Smyles_
Denmark
They'll be dropped into my 130 build in the coming months, so I've not put much thought into it yet but I know what you mean about bump stops. I'll be running compressed air on the truck so the plan is to use a Firestone 1T26D-7 air spring in each corner instead of a conventional coil. This will give a theoretical travel of 378 mm (at least according to this diagram) although my upper bound will be limited by the 9 inches of shock travel.
However yes, from what I understand my desired setup will require larger bump stops and limiting straps as I don't particularly want airbags dislocating as I hear the bags can get pinched when relocating with cones, potentially causing a puncture... Stuart
Cummins 130 Build Thread
Instagram
58 130 Double Cab HCPU - Cairns Blue
04 110 Double Cab - Black (gone)
07 Audi RS4 Avant - Silver
Post #888926 4th Mar 2021 12:47am
jonny
Thanks Matt110 / Likeomg for the feedback, sounds like they are a worthwhile upgrade...
My wallet may thank you a bit less later though Wink
Post #888952 4th Mar 2021 8:50am
jonny
Ordered Very Happy
Just looking at options for shock boots / covers at the moment, looks like the proper covers are out of stock for a few months at Prolinx...
Post #888968 4th Mar 2021 10:09am
Smyles_
Denmark
Good news!
Prolinx got back to me this morning and it is possible to install the compression adjusters on these shocks:
"The cost would be £30 per shock to fit them plus £40 per shock to revalve the unit to suit, plus the cost of the adjuster.
Prices are plus VAT."
That makes it £149.44 cheaper to buy the non-adjusting shocks and have them installed with the compression adjusters by Prolinx. That's for all four including VAT, but not postage to and fro. Stuart
Instagram
Post #888981 4th Mar 2021 11:11am
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Well this impulse purchase is getting more and more expensive Laughing
Post #888984 4th Mar 2021 11:25am
Smyles_
Denmark
Nothing wrong with dabbling in retail therapy Razz
I'll likely get my rears done sometime down the line, but it'll still come out £364.64 less than buying the same setup (non-adjust front/adjustable rear) at full price! Stuart
Instagram
Post #888994 4th Mar 2021 11:47am
Matt110
Sounds good. Have you worked out how much extra bump stop is needed? By my reckoning it's approx 40mm to get to a non bottomed out shock when the bump stop is used.
Where have you found to get axle travel limit straps from? Am thinking that's also my solution as I don't want to dislocate even with springs, but can't find any or anyone who knows anything about them or the set lengths.
Post #889063 4th Mar 2021 6:18pm
Smyles_
Denmark
Not too sure on the bump stop sizes, but I believe standard bump stops are 58 mm in height. My advice would be to contact the folks over a Gwyn Lewis, they'll be able to tell you for sure, but I suspect that you'll require an extended set.
As for limit straps, that's easy. Just jack the truck up to full droop on the spring (usually it's full droop on shock but in your case you want the uncompressed spring to be the limit) measure from the 2 points where the straps will be attached and order yourself an appropriately long set. The front and rear may differ a bit up to 60 mm. (source)
Video here that better explains it despite his car being made of scaffold...
Just one place I found to buy some
Off Topic I then got distracted on anther site looking at straps and I now want one of these... Shocked Stuart
Instagram
Post #889153 5th Mar 2021 1:32am
Likeomg
Id also recommend some new turrets to show off these shiny new shocks...
I went with adrenaline 4x4
Post #889154 5th Mar 2021 2:43am
jonny
Mine just arrived, can't fault the delivery speed Smile
Now to search for some shields / boots...
Post #889189 5th Mar 2021 9:39am
Kev9t
England 2007 Defender 90 Puma 2.4 CSW Java Black
Hiya guy’s glad you have all grabbed a bargin any other bargains i find I know where to post them Thumbs Up
Post #889284 5th Mar 2021 6:11pm
Smyles_
Denmark
Yes please! You're an absolute legend for this one, especially given how many seem to be available! Thumbs Up Stuart
Instagram
Post #889285 5th Mar 2021 6:20pm
sykes705
United Kingdom 2005 Defender 110 Td5 XS CSW Epsom Green
Can theses be used without a 2” lift?
As in, using standard springs?
Post #889325 5th Mar 2021 8:53pm
Matt110
It's not the lift that's the problem, it's the compressed shock length.
By my reckoning yes you can fit to the front with only a +2" turret.
But the rear there's no getting out of dislocation cones and spring retainers at full droop, and +25mm bump stops.
Post #889329 5th Mar 2021 9:02pm
Page 2 of 4 <1234>
