Home > General & Technical (L663) > Odd 90 question ... passenger window |
Scrumps Member Since: 24 Feb 2021 Location: Somerset Posts: 108 |
Hi Vern,
Have you tried the window reset procedure just in case it’s not been done since build or part of QA/PDI? https://www.ownerinfo.landrover.com/docume...c/G2260999 Scrumps 90 D250 HSE Tasman Blue 24MY L461 RRS Verasine Blue 05 TD5 90 CSW Cairns Blue 1967 MGB BRG 1944 Willy’s MB OD green 1942 Willy’s MB OD green |
26th Feb 2021 7:23pm |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1326 |
Doesn't sound right to me and I suspect the dealer is trying to avoid an issue.
If the window goes all the way down on the driver's side, why wouldn't it do the same on the passenger side. I suspect the window mechanism hasn't been fitted correctly. |
26th Feb 2021 8:41pm |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 |
I will check mine tomorrow and let you know
27th Feb 2021 12:24am |
Vern Member Since: 04 Feb 2021 Location: England Posts: 38 |
Thanks .. given it a go but not worked sadly |
27th Feb 2021 2:32pm |
Thanks it’s very odd |
27th Feb 2021 2:35pm |
Vern,
I’ll get them to check SWMBO’s @ PDI next week. Scrumps 90 D250 HSE Tasman Blue 24MY L461 RRS Verasine Blue 05 TD5 90 CSW Cairns Blue 1967 MGB BRG 1944 Willy’s MB OD green 1942 Willy’s MB OD green |
27th Feb 2021 2:41pm |
Click image to enlarge Click image to enlarge Both right and left are identical, there is about a centimetre that sticks up. |
27th Feb 2021 3:01pm |
Suspect yours aren't 100% adjusted as well Digger2000. Either that or its JLRs way of discouraging you from driving with your elbow out of the window
27th Feb 2021 3:13pm |
I’ll live with it they are the same as my bmw and these doors are thick doesn’t cause a problem with my elbows. Got to remember the 110 has a smaller window the doors are longer on the 90 and the window tapers toward the rear of the car same as the roof line.
27th Feb 2021 3:20pm |
Hi thanks .. at least we are not alone .. oddly ours is just passenger .. like you might not mess. |
27th Feb 2021 3:45pm |
So .. as it was bugging me a tried the window reset that is in the e Manual again and nothing .. so I googled and there are other more complex resetting procedures.. that involve listening for a click. Tried loads and it worked ... window went all the way down .. very chuffed with myself .. turned car off and on again and and it had gone back to sticking up a bit
Having seen the window go all the way down now I’m even more annoyed |
28th Feb 2021 10:11am |
Vern,
Can you post the link to the procedure please? Scrumps 90 D250 HSE Tasman Blue 24MY L461 RRS Verasine Blue 05 TD5 90 CSW Cairns Blue 1967 MGB BRG 1944 Willy’s MB OD green 1942 Willy’s MB OD green |
28th Feb 2021 10:28am |
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 |
And next time you get the window all the way down, for goodness sake take a pic otherwise the dealer will say “but they all do that, sir”.
28th Feb 2021 10:30am |
