![]() | Home > General & Technical (L663) > MY22 V8 supercharger on the way |
Griff90bowler Member Since: 24 Feb 2021 Location: Cowbridge Posts: 134 ![]() ![]() |
Can someone tell me if the V8 has a exhaust valve I’m guessing it’s when switched to dynamic
lazurus Member Since: 22 Aug 2021 Location: England Posts: 10 ![]() ![]() |
Can’t say I notice a difference
jhlooking Member Since: 17 Sep 2021 Location: lockerbie Posts: 8 ![]() ![]() |
Get yourself on your back and get under the cars exhaust, there is a plug on each exhaust, unplug them but put them back in the socket but dont put them in fully, its just to keep them dry, it opens the exhaust vales all the time ![]() ![]() |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7916 ![]() ![]() ![]() |
That sounds an easy fix
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
If it's the same setup as the L494/L405, there's no need to splash megabucks on an expensive exhaust system when you can get your local exhaust shop to replace the resonator & centre silencer boxes with straight or X/H-pipes. ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Yeah you could do this I guess.
It’s around £2.3k
YulongTD6 Member Since: 06 Mar 2021 Location: USA Posts: 27 ![]() |
How are you all liking the V8 after some time?
