![]() | Home > Maintenance & Modifications > Rear door lock barrel removal - no pin hole |
Bev Member Since: 03 Apr 2013 Location: Perthshire Posts: 267 ![]() ![]() ![]() |
It’s definitely there. On the newer style doors the pin hole is not as visible as it’s is on older type doors. Having just gone through this change myself, I found the pin hole to be accessible from the inside of the rear door lock mechanism.
If you have the door lock off you need to look down inside the mechanism from the opening that the handle moves in. The pin hole might be covered in crud and dirt but it is there. You should see it behind the metal plate, Not on the outside door barrel itself. I don’t have my truck here to take a photo sadly and nothing come up on google search 2002 Td5 | 90 County Station Wagon | Oslo Blue 2006 Td5 | 90 County Station Wagon | Tonga Green (Gone ) 2002 Td5 | 90 County Station Wagon | Zambezi Silver (Gone) |
Ashbyandy Member Since: 17 Dec 2015 Location: Leicestershire Posts: 224 ![]() ![]() ![]() |
![]() Click image to enlarge Photo attached showing hole circled in red, not easy to find as Bev said, Ashbyandy 👍 |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 ![]() ![]() ![]() |
Had the same issue - as the guys have said, once you know what you are looking for......... Rgds.
Chris |
wynn153 Member Since: 30 Nov 2020 Location: Cheshire Posts: 31 ![]() ![]() |
Thanks a lot, very helpful.
Sorry for the delay |
SteveP Member Since: 18 Mar 2017 Location: Devon Posts: 1 ![]() ![]() |
Thanks, a picture makes it so much easier to find.
