Home > In Car Electronics > Reversing Spotlight |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3757 |
Hi
I fitted this just wired to existing light? seems to work ok? Click image to enlarge |
20th Feb 2021 4:09pm |
Tr90 Member Since: 06 Jan 2020 Location: Essex Posts: 135 |
I did the same. Straight in to the reversing but also added the ability to turn it on as a work light from the rear and the front.
Handy to get people to back off when travelling close🤥 Click image to enlarge |
20th Feb 2021 7:13pm |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 |
Perfect thanks all.
20th Feb 2021 8:12pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
Straight to the reverse light on mine too.
2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
20th Feb 2021 9:53pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8051 |
I fitted a classic car led after a link on a post I asked about reversing lights on here, no additional lights needed! Cheers
20th Feb 2021 10:46pm |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 685 |
Any chance of directing to the one you bought? I can't ever see my parents neighbours bush in the dark... The thing is gradually getting flattened by my spare wheel lol. Changing out the bulb for an LED would be ideal.
20th Feb 2021 10:54pm |
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 |
Like the bracket the light is fitted on , and info where to get one ? đź‘Ť Stew |
21st Feb 2021 8:03am |
It’s a farCorners item. At nearly 5 years old it’s ageing well. Does require a couple extra holes to bolt it to the tub too, has a nice reinforcing plate on the inside to spread the extra weight of the light also.
Also houses an LED number plate light. It does stick out a bit more than standard so not really suitable if you have a rear ladder. Unless you’re careful with your footing. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
21st Feb 2021 9:16am |
Thanks for that
Stew |
21st Feb 2021 9:48am |
Just ordered a few bits from them
21st Feb 2021 10:58am |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 |
There is also this..
Click image to enlarge Cheers Don. |
21st Feb 2021 2:57pm |
^ My led light was ÂŁ7 for 2.
Attaches to the plastic number plate holder. Does the job |
21st Feb 2021 4:51pm |
To be fair I took the inspiration from Stacey007
21st Feb 2021 7:08pm |
https://www.classiccarleds.co.uk/collectio...6-p21w-382 Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
21st Feb 2021 10:34pm |
