Home > In Car Electronics > Reversing Spotlight
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Reversing Spotlight
I've got a cheap LED reversing spotlight that pulls about 3.2 Amps. Can I wire that straight into the existing reversing light or do I need a relay? Planning on fitting without a switch, it just comes on when the car is in reverse.
Thx
J
Post #886738 20th Feb 2021 1:38pm
Stacey007
Hi
I fitted this just wired to existing light? seems to work ok?
Post #886774 20th Feb 2021 4:09pm
Tr90
United Kingdom 2000 Defender 90 Td5 CSW Alveston Red
I did the same. Straight in to the reversing but also added the ability to turn it on as a work light from the rear and the front.
Handy to get people to back off when travelling close🤥
Post #886806 20th Feb 2021 7:13pm
boxoftricks
Perfect thanks all.
Post #886823 20th Feb 2021 8:12pm
Roy5695
Straight to the reverse light on mine too.
 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #886845 20th Feb 2021 9:53pm
jst
I fitted a classic car led after a link on a post I asked about reversing lights on here, no additional lights needed! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #886852 20th Feb 2021 10:46pm
Matt110
Any chance of directing to the one you bought? I can't ever see my parents neighbours bush in the dark... The thing is gradually getting flattened by my spare wheel lol. Changing out the bulb for an LED would be ideal.
Post #886854 20th Feb 2021 10:54pm
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Like the bracket the light is fitted on , and info where to get one ? đź‘Ť
Stew
Post #886878 21st Feb 2021 8:03am
Roy5695
It’s a farCorners item. At nearly 5 years old it’s ageing well. Does require a couple extra holes to bolt it to the tub too, has a nice reinforcing plate on the inside to spread the extra weight of the light also.
Also houses an LED number plate light.
It does stick out a bit more than standard so not really suitable if you have a rear ladder. Unless you’re careful with your footing. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #886886 21st Feb 2021 9:16am
stew 46
Thumbs Up Thanks for that Thumbs Up Thumbs Up
Stew
Post #886893 21st Feb 2021 9:48am
stew 46
Just ordered a few bits from them Thumbs Up Thumbs Up
Post #886907 21st Feb 2021 10:58am
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
There is also this..
 Cheers Don.
Post #886935 21st Feb 2021 2:57pm
Stacey007
^ My led light was ÂŁ7 for 2.
Attaches to the plastic number plate holder.
Does the job Thumbs Up
Post #886949 21st Feb 2021 4:51pm
Tr90
To be fair I took the inspiration from Stacey007
Post #886994 21st Feb 2021 7:08pm
jst
https://www.classiccarleds.co.uk/collectio...6-p21w-382 Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #887048 21st Feb 2021 10:34pm
