Home > Puma (Tdci) > Puma water ingress
Lake_District
Puma water ingress
Hi everyone, I’m sure I’m not alone in having water leaks on my 64 Puma. Got in the car the other day to find these water marks underneath the central tunnel and rusty water in the mats.
Anyone any ideas? Doesn’t appear to be any water coming through the windscreen.
And help much appreciated.
2nd photo is passenger side.
I have managed to get behind the dash, and the water has been collecting in these troughs, which you screw the lower dash screws into. Water obviously sits there given the rust! Question is where is the water coming from?
Hope someone can offer some advice. Thank you.
Ed
 Cars, got to love them
Defender 90 XS Santorini Black
Discovery 3
Ford Cortina Mk 3
Ford Spartan
VW T25 Camper Van
SAAB 9-5
Post #886727 20th Feb 2021 2:08pm
jcw
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
I think that bracket is located higher than the fan opening which can leak, so more likely to be one of the following
1. Windscreen surround rubber seal
2. Windscreen frame to bulkhead foam seal
3. Window block seals
4. LHD wiper hole grommets
Post #886775 20th Feb 2021 5:11pm
Lake_District
Thank you for the reply. That bracket with the rust, is level with the bottom of the dash. Is it an easy job to change the windscreen seal? I had a new screen fitted some 5 years ago. Is it an easy job to replace? Cars, got to love them
Discovery 3
Ford Cortina Mk 3
Ford Spartan
VW T25 Camper Van
SAAB 9-5
Post #886782 20th Feb 2021 6:16pm
nitram17
Re: Puma water ingress
Ed
[img:480:640]https://www.defender2.net/gallery/albums/userpics/21276/E8D57C27-7331-475F-961F-
most likely the E4BCF315B7BD.jpeg[/img]
Most likely the windscreen seal or the bulkhead seal if it was on the near side i might think it would be the blower seal. You need to seal the windscreen with some flexi seal and cram some captain trolleys into the bulkhead seal (or seal with silicone or acf blue grease)..Try lifting the rubber of the windscreen seal after it has rained then you will be amazed at the water thats under the rubber!
Post #886785 20th Feb 2021 6:31pm
Lake_District
Thanks for the reply, something to work with. Cars, got to love them
Discovery 3
Ford Cortina Mk 3
Ford Spartan
VW T25 Camper Van
SAAB 9-5
Post #886792 20th Feb 2021 6:49pm
Fat Cog
This also works on the windscreen seal...
https://www.eurocarparts.com/p/u-pol-tiger...UPL.TIG_NB Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #886798 20th Feb 2021 7:22pm
Co1
I had a similar leak and traced it back to window block seal. The idiot that fitted it (me), hadn’t done the top boot up properly. The gaskets go on them quite often and they are only a few pence and a 10 min job so worth doing.
Post #886807 20th Feb 2021 8:14pm
Trundlebus
I had a leak in a similar area, though only a small amount, on the passenger side. I worked out iw due to the silly sponge seal on the bulkhead where the scree joins the body. I used Captain Tollys creeping crack cure, just let it soak in and the problem went away for 2 years , It started again recently but a further application stopped iy again
Post #888682 2nd Mar 2021 8:08pm
Trundlebus
Post #888692 2nd Mar 2021 8:37pm
Oldowner
It doesn’t help that the bracket you have pictured was fitted without any form of plating or paint from the factory - incredulously it was bare unprotected steel, so pretty much every Puma has a rusty bracket, water ingress or not, but as it’s hidden behind the dash no one really realises.
Post #888705 2nd Mar 2021 9:09pm
