Home > Puma (Tdci) > Puma Brake pad Life
Vitesse
Puma Brake pad Life
Just wondering how much brake pad life others are getting ? I use my 90 Defender as a daily drive and have owned it from new in 2015. I replaced the original factory pads at 34000 miles and they still had about 6 mm of material. I just replaced them again the other week (EBC Red) and now its at 71000 miles. This time the pads were less than half worn!! The discs are all original.
I appreciate that the use of vehicle is a huge contributory factor but I do run it daily on all road types. I am not complaining but interested if this is usual? Thumbs Up 2015 90 XS Santorini Black
Post #886475 19th Feb 2021 11:49am
Dinnu
From a vehicle point of view, the Puma engine has the lowest compression ratio, so in terms of engine braking it has the least resistance, so more use of the brakes.
Of course different brake pads have different wear characteristics. I tend to prefer the pads that wear faster, as I have feeling that they wear the discs less. But discs are not as expensive anyways.
Though all Defenders have good air brakes Rolling with laughter 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #886493 19th Feb 2021 12:52pm
Martin
Site Admin
The DSC system on the 2015-2016 models kicks in more than you think and is pretty aggressive on the brake pads.
My 90 has been through front and rear pads in 36k miles.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #886501 19th Feb 2021 1:10pm
LR90XS2011
my original factory pads lasted about 30k before I changed them but still had plenty of life left DEFENDER 90 TDCI XS,
Post #886505 19th Feb 2021 1:17pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
There are so many things that can change the life expectancy of your pad life, from the pad material, to usage and environment and conditions you drive in including your load weight, but if your getting 30k of life I don’t think you need to worry unnecessarily.
A new vehicle has the best chance of long brake life for its first set, as everything is fresh and new, and new vehicle OE pads normally have thicker friction material. Also, replacement pads bed in to the brake disc wear grooves quickly which takes valuable life from them but it’s important this happens quickly as it increases the contact surface area making them efficient.
Also, Traction or Stability control is one driver aid that reduces the life of your pads, your vehicles is systematically braking individual wheels without your knowledge to keep your vehicle balanced, controllable and moving in the correct direction. A small price to pay for added safety.
Braking is a waste of energy so save on fuel... brake less Rolling with laughter Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #886507 19th Feb 2021 1:24pm
Julie
100 000 kms on original pads from Solihull - but it's not the best model for most of us
I don't have ABS nor TC Sheep
P.S. The garage didn't even want to change thé rear ones, they were at 30%
Post #886600 19th Feb 2021 7:30pm
dgardel
Italy
Quite same here 90.000km...
no ABS Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #886657 20th Feb 2021 1:26am
Grenadier
My first swap was approx 65k front, 80k rear (miles). But then I live in the mountains, so lots of heavy braking on long descents. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #886664 20th Feb 2021 7:31am
Vitesse
Thanks for all the replies. Looks like a similar experience to my own Thumbs Up 2015 90 XS Santorini Black
Post #886703 20th Feb 2021 10:02am
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
62,000 and still have 8mm on the front pads😃.
Post #952911 18th May 2022 8:26pm
UtilityTruck
My puma (110 utility) seems much heavier on rear pads, possibly due to the much smaller pad size. I changed the rear pads at approx 40kmiles and just changed the front+rear at 85k. The fronts still had useable material on, despite being a bit tapered. Discs didn’t need changing. 2014 Keswick Utility 2.2
Post #952980 19th May 2022 5:16pm
