Home > In Car Electronics (L663) > Digital dash -- yea or nay?
Page 2 of 2 <12
DSL
Big Cry Big Cry Big Cry Big Cry Big Cry
Post #892370 18th Mar 2021 3:55pm
expatbrit
United States
walfy wrote:
Its a £300 option, be daft not to in my mind.
I've spent ages on the configurator building various versions of the car I want, and this option has been ticked on every build
Honestly, it was one of the things I left off until the last minute for whatever reason, but it went on (at the MY21 rates, and even in USD!). I've always been happy with nice analogue sweeps, but this lot of reprobates convinced me... D110 P300 (now here) -- Pangea Green / white roof / white steelies / Off-road pack / towing pack / cold-weather pack / heated seats and assorted fun odds and sods
Post #892376 18th Mar 2021 4:13pm
Gareth
I keep mine dead simple with the 2 dials and the analogue clock in the middle. When I’m using nav it pops up junction info when needed. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #892383 18th Mar 2021 4:21pm
J77
DSL wrote:
Can CarPlay (Google Maps there-on) be shown in a decent sized window on the DigiDash? Question
I just use LRs own navigation for this reason.
On the velar I always have the map displayed between the dials. Though I do like the analog clock on the Defender. 24MY 90 D250 HSE, Tasman Blue
Post #892409 18th Mar 2021 5:44pm
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
I have the 4x4i screen with the differentials showing on mine
Post #892430 18th Mar 2021 6:49pm
expatbrit
United States
I bet you do, given all your AWD issues! D110 P300 (now here) -- Pangea Green / white roof / white steelies / Off-road pack / towing pack / cold-weather pack / heated seats and assorted fun odds and sods
Post #892933 21st Mar 2021 4:36am
Gareth
One problem I find with having the map showing between the dials all the time, is that it’s too dim to see! Unless you have a programmed route showing it’s impossible to read it properly. The junction pop up is fine. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #892941 21st Mar 2021 7:09am
J77
It should be in full colour, blue for water etc, if not LR will need to look at this, because in the Velar I can switch between the two, seems a backwards step if you can’t in the Defender. 24MY 90 D250 HSE, Tasman Blue
Post #892988 21st Mar 2021 11:01am
Gareth
It is full colour, just dim. It’s not so bad in daylight when the display is bright, but as soon as it’s dusk and the system switches to night mode, I found it dim. I know you can set the scheme to bright in the settings, but I found that too bright on the Pivi screen at night.
Maybe I’m hard to please! I like the clock. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #893001 21st Mar 2021 11:42am
Digger2000
Rolling with laughter Yep I probably keep this setting permanently now
Post #893003 21st Mar 2021 11:46am
Digger2000
Btw the dim display is a fault this is part of the reason my differentials were glitching. There’s a patch being developed now scheduled to release next month, it has to be installed at the dealership though not over the air.
Post #893007 21st Mar 2021 11:52am
J77
Thumbs Up
I think I’ll have the clock just for the novelty of it. 24MY 90 D250 HSE, Tasman Blue
Post #893012 21st Mar 2021 12:47pm
expatbrit
United States
At least I’ll be able to claim (probably without basis in fact) that it’s the displaying being dim, not me??? D110 P300 (now here) -- Pangea Green / white roof / white steelies / Off-road pack / towing pack / cold-weather pack / heated seats and assorted fun odds and sods
Post #893024 21st Mar 2021 2:55pm
Tim in Scotland
Gareth you aren’t the only one that isn’t happy with the contrast of the map in the main driver info screen, when it goes to nighttime setting (and that seems to be independent of when the headlights come on) it does it in quite high light levels and it is unreadable. The thumb wheel illumination adjuster down by the manual switch for the parking brake seems to make no difference too. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed!
Post #893139 22nd Mar 2021 8:37am
Page 2 of 2 <12
