Home > In Car Electronics (L663) > Digital dash -- yea or nay? |
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 |
18th Mar 2021 3:55pm |
Gareth Member Since: 12 Dec 2011 Location: Bramhall Posts: 1102 |
I keep mine dead simple with the 2 dials and the analogue clock in the middle. When I’m using nav it pops up junction info when needed. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
18th Mar 2021 4:21pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3396 |
I just use LRs own navigation for this reason. On the velar I always have the map displayed between the dials. Though I do like the analog clock on the Defender. 24MY 90 D250 HSE, Tasman Blue |
18th Mar 2021 5:44pm |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 |
I have the 4x4i screen with the differentials showing on mine
18th Mar 2021 6:49pm |
expatbrit Member Since: 02 Jan 2021 Location: NM Posts: 74 |
I bet you do, given all your AWD issues! D110 P300 (now here) -- Pangea Green / white roof / white steelies / Off-road pack / towing pack / cold-weather pack / heated seats and assorted fun odds and sods
21st Mar 2021 4:36am |
One problem I find with having the map showing between the dials all the time, is that it’s too dim to see! Unless you have a programmed route showing it’s impossible to read it properly. The junction pop up is fine. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
21st Mar 2021 7:09am |
It should be in full colour, blue for water etc, if not LR will need to look at this, because in the Velar I can switch between the two, seems a backwards step if you can’t in the Defender. 24MY 90 D250 HSE, Tasman Blue
21st Mar 2021 11:01am |
It is full colour, just dim. It’s not so bad in daylight when the display is bright, but as soon as it’s dusk and the system switches to night mode, I found it dim. I know you can set the scheme to bright in the settings, but I found that too bright on the Pivi screen at night.
Maybe I’m hard to please! I like the clock. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
21st Mar 2021 11:42am |
Yep I probably keep this setting permanently now |
21st Mar 2021 11:46am |
Btw the dim display is a fault this is part of the reason my differentials were glitching. There’s a patch being developed now scheduled to release next month, it has to be installed at the dealership though not over the air.
21st Mar 2021 11:52am |
I think I’ll have the clock just for the novelty of it. 24MY 90 D250 HSE, Tasman Blue |
21st Mar 2021 12:47pm |
At least I’ll be able to claim (probably without basis in fact) that it’s the displaying being dim, not me??? D110 P300 (now here) -- Pangea Green / white roof / white steelies / Off-road pack / towing pack / cold-weather pack / heated seats and assorted fun odds and sods |
21st Mar 2021 2:55pm |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
Gareth you aren’t the only one that isn’t happy with the contrast of the map in the main driver info screen, when it goes to nighttime setting (and that seems to be independent of when the headlights come on) it does it in quite high light levels and it is unreadable. The thumb wheel illumination adjuster down by the manual switch for the parking brake seems to make no difference too. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
22nd Mar 2021 8:37am |
