Home > Td5 > TD5 - Fuel Filter
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
TD5 - Fuel Filter
Anyone else had this issue,
When I order a fuel filter I get one which should have the water in filter warning switch fitted, of which my 90 dosent have one!
Its a ball ache every time as the drain valve is too small to plug the hole, should i just buy the switch to solve the hassel! Or is there another filter for a TD5 which I should be getting?
Post #83265 6th Aug 2011 6:26pm
landy andy
When I get a fuel filter, I always have got the one I require. Did not even know that the filters them self were different, just assumed they would be. So can't understand why I have always got the correct one as nobody has ever asked which I require. I like you don't have water sensor.
Andy
Post #83289 7th Aug 2011 7:35am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
All td5 fuel filters are the same wether with sensor or drain bung, the drain bung is avalible seprate once you have just swap it over when its time for a filter change
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #83300 7th Aug 2011 9:38am
Paul_1978
Thanks for the info, just had a look at the parts and there is a drain off that fits on the bottom, you would have thought it would come with the filter!
The drain is part number YXJ500060NAA and costs 4.34 a genuine filter is 37.84 for that price you would expect it to come with it!
Ive put a stainless bolt and a rubber washer on it for this year.
Post #83301 7th Aug 2011 10:29am
