Home > Td5 > TD5 - Fuel Filter |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5741 |
When I get a fuel filter, I always have got the one I require. Did not even know that the filters them self were different, just assumed they would be. So can't understand why I have always got the correct one as nobody has ever asked which I require. I like you don't have water sensor.
Andy |
7th Aug 2011 7:35am |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 559 |
All td5 fuel filters are the same wether with sensor or drain bung, the drain bung is avalible seprate once you have just swap it over when its time for a filter change
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
7th Aug 2011 9:38am |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 |
Thanks for the info, just had a look at the parts and there is a drain off that fits on the bottom, you would have thought it would come with the filter!
The drain is part number YXJ500060NAA and costs 4.34 a genuine filter is 37.84 for that price you would expect it to come with it! Ive put a stainless bolt and a rubber washer on it for this year. |
7th Aug 2011 10:29am |
