![]() | Home > Wheels & Tyres (L663) > will discovery sport 19" wheels fit the new 2020 defend |
They might physically fit but I'd be wary about whether they'd be rated for the weight of a Defender. Darren
cozz Member Since: 15 May 2013 Location: nottingham Posts: 547 ![]() |
ive got some off a disco 5 to fit,
surely a disco 5 is heavier than a 90 hardtop ? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6661 ![]() ![]() ![]() |
Different PCD. Disco Sport is 5x108 (same as Evoque and Freelander 2).
New Defender (and D3/D4/RRS/L322/L405) are 5x120. ![]() ![]() |
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 ![]() ![]() |
So have I got this right, standard D3/4 rims will fit, without spacers?
SN Member Since: 30 Jun 2007 Location: SK6 Posts: 729 ![]() |
Its the spacer/offset thing that I'm not sure of - Mr Searles has already stated elsewhere that D3/D4/D5 wheels will fit
My research says D3/D4 18's (which interest me) rims are (for 255/60R18 112V tyres) 8Jx18 ET53 5x120 And the New Defender 18's rims are (for 255/70R18 116V tyres) 8Jx18 ET41.5 5x120 With an ET value of 53 the D3/D4 rims will stick further out by 11.5mm as compared to the New Defender rims. Is this an issue? No idea. BTW - someone please correct me if I got this wrong! ![]() I still have a D3 18" wheel with a Zero on it thats only done literally 200 miles ![]() I wish I'd kept those lovely 19" RR Sport Rims I had on the D3, they would have looked excellent on the New Defender. Steve N | 21MY Defender ![]() ![]() ![]() |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 ![]() ![]() |
I think the larger ET on the D3/4 Rims will mean they stick IN not OUT more
As its the distance between the Hub Face and the centreline of the rim - larger - more in towards suspension - smaller more it sticks out.. |
Thanks for checking that - I was actually thinking about this last night after I'd posted it. So a spacer might be required then? Steve N | 21MY Defender ![]() ![]() ![]() |
You may get away without a spacer as the 22" wheels use 275 tyres - so already 10mm wider - as have lots of people who fitted BFG 275 55 20 tyres...
Its a suck and see - but believe spacers are available in 30mm widths... |
Nelu Member Since: 07 Jun 2021 Location: Constanta Posts: 6 ![]() ![]() |
I tried to fit r18 D3 on my D200 and doesn't fit. It was rubbing on the calipers. I even tried with 30mm spacers.
