Home > Maintenance & Modifications > Fox Shocks Remote Res with adjusters C/D Experience |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4795 |
Hi welcome to the forum. Try the search button at the top middle of the home screen , several here have them fitted, I have the non adjustable ones and really like them but don’t off roading but on tarmac well impressed 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
1st Feb 2021 9:50pm |
The.devon.defender Member Since: 01 Feb 2021 Location: Salcombe, Devon Posts: 7 |
Thanks! I’ve been searching all eve, trying to find out specific bits about them. How long have you had them for? Any signs of corrosion/wear?
1st Feb 2021 9:57pm |
Thanks! I’ve been searching all eve, trying to find out specific bits about them. How long have you had them for? Any signs of corrosion/wear? |
1st Feb 2021 9:59pm |
About 18 months no signs yet of corrosion. Forum member likeomghas them on his and he fitted shield he brought in America I think to help protect them https://www.defender2.net/forum/topic15909...fox+shocks 2015 HT XS 90
1st Feb 2021 10:10pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3670 |
I have non Adjustable ones. Great performance but the rears are vulnerable without the protectors that LikeOMG links to on his thread. I had one exchanged under warranty as the stone chips were so bad, so bought the protectors and now no issues.
2nd Feb 2021 6:06am |
I was recommended them whilst talking to prolinx, sounds like a no brainer. I’m also going to get the main bodies wrapped in a clear vinyl protection to help prevent the pebble dash ally powdering effect everyone seems to get. |
2nd Feb 2021 9:17am |
Sounds like they have a good warranty then! This sounds like a common issue, but so far the only one! Are you lowered/gone through alive tuning’s kit or still use the landy offroad? Whats the articulation like? |
2nd Feb 2021 9:19am |
Maverick XS Member Since: 07 Apr 2020 Location: London Posts: 13 |
Hi, I have Fox 2.0 adjustable remote reservoir all round on my 90. I'm very impressed with the comfort and handling. I would definitely recommend them. I've had them for just over a year (circa 5000 miles) and they are still in good condition. My truck is not used off road apart from the occasional track. So I cant comment on off road performance and wear. I had the Bilstein B6 before and found them a bit harsh and crashy on anything more than flat tarmac. The Fox's are far superior!
Click image to enlarge Click image to enlarge Click image to enlarge |
2nd Feb 2021 11:56am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7904 |
Member John Fair has them fitted https://www.defender2.net/forum/topic46611-75.html James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
2nd Feb 2021 12:38pm |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 680 |
Hiya, any chance you would be able to take some photos or describe how and where you mounted the remote Res? Which side of the strut tower did you exit with the Res hose? Fitted mine last night but currently now trying to find a good location for the reservoirs each side. Nearside appears vastly simpler than offside. |
22nd Aug 2022 8:10am |
MercianRover Member Since: 07 Apr 2022 Location: Culworth Posts: 141 |
I've had Fox 2.0 x 12" Emulsion on my 100" Bowler since 2007ish with around 60,000 miles on them.
Mixed use from commute and rapid road use to green laning in all seasons and rally course-closing car. They have heim joints top and bottom which are greased and last well. They were serviced back in 2016 and had flutter valving with different pistons fitted which made a big difference to ride quality on pave and similar, although they were excellent before. Not convinced that remote reservoirs are needed unless you are racing, similarly with the compression/rebound adjusters. Observations? Keep them clean and occasional spray of WD40 or similar. Use check straps to limit axle travel, do not expect the dampers to do this job. The ride and handling mean it is very easy to keep up with cars even on fast A roads so be sure your brakes and especially tyres are up to the job. |
22nd Aug 2022 10:06am |
