Home > Puma (Tdci) > Estimate on labor time
Ben01
Can someone give me a rough estimate on time for replacing the following parts?
It can be a very rough estimate. The fuel pump and temperature sensor (it broke coming out) took the most time. Thanks.
Fuel Pump
Themostat
Fuel Sender and checking tank, fixing hose
Injectors
Sensors/Filters/oil change, coolant (MAP, MAF, Fuel Filter, Oil Filter, Coolant, fuel pressure sensor and regulator)
ECM install
Install: Steering damper, steering guard
Temperature sensor and crankshaft sensor
Post #880796 25th Jan 2021 2:45pm
familymad
A full days labour 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #880797 25th Jan 2021 3:09pm
Ben01
thanks, much appreciated.
Post #880803 25th Jan 2021 3:35pm
jst
thats assuming it all went to plan for a full day and depends how long a full day is.
injectors dont always come out nicely
full tank , assuming comes out no rusted up tow bars etc, half a day
thermostat just under an hour
steering damper and steering guard and hourish
fluids, filters and sensors another hr ish. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #880835 25th Jan 2021 6:08pm
