Home > Technical > OBD Splitter
jst
OBD Splitter
Morning,
i am looking at adding a scanguage to my 2.4 130 and would like an OBD splitter so a port is available whilst the scanguage is plugged in.
Is the OBD an OBD2 16 pin? so would this work? https://www.amazon.co.uk/FireAngels-Profil...ooghydr-21 Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #879668 20th Jan 2021 9:11am
hank
That would work.
From memory, when I used an OBD extension temporarily, you will need to dismount the vehicle OBD port from its frame as in the original position there is insufficient clearance to refit the fusebox cover with one of of those 90 degree plugs plugged in > 110 XS Double Cab
Post #879677 20th Jan 2021 9:39am
jst
perfect, thank you Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #879741 20th Jan 2021 3:28pm
walfy
That looks a better option that what I have fitted currently. Like was said, you need to dismount the socket from the board to fit. But looking at the version you linked to, I reckon you might get away with not having to do that.
If it works then let us know as i'd probably go the same route. Such an splitter wasn't available when I looked and purchased a couple of years ago 110 D250 SE HT
110 USW SOLD
Polaris RZR 900XP SOLD
Post #879753 20th Jan 2021 4:03pm
hank
When I had one of the below fitted temporarily (to monitor some parameters using by BAS tool) I could not refit the fusebox lid. Only one screw though to dismount the socket from the frame
 > 110 XS Double Cab
Post #879766 20th Jan 2021 4:51pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
OBD is found on pre 90 vehicles, OBD2 is a later manufacturer universal version of the same plug that allows more Bluetooth and wireless accessibility.
If your using a wired device even with a Y splitter you shouldn’t encounter any problems Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #879770 20th Jan 2021 5:24pm
