Home > For Sale & Wanted > [For Sale] Defender auto conversion bits ZF4HP22
TVR Tommy
United Kingdom 2000 Defender 90 Td5 Heritage LE Bronze Green
I've gone and pulled the hydraulic ZF4HP22 out of my defender to swap with a later electronically controlled box.
So I have
1X ZF4HP22 Hydraulic Box
1X TD5 bell housing
Standard TD5 torque convertor and flex plate, spacer and bolts
kickdown cable and mount where it comes through the firewall. I had to cut the kickdown bar off the pedal so will need reattaching
Gearbox works fine selects all gears. I do have an invoice for a gearbox rebuild that was done on the box 20k miles ago.
You'll need a shifter. I reused the Discovery 1 shifter. But I do have a D2 shifter but no cable to box for that.
So if you fancy converting your TD5 to a cheap auto you can take the lot for £200
Post #879580 19th Jan 2021 3:35pm
drakes
United Kingdom 2004 Defender 90 Td5 HT Auto Belize Green
If I had not already done this I would have snapped this up, can recommend it to anyone as it really does make a nice drive in a TD5
Post #879729 20th Jan 2021 1:57pm
TVR Tommy
Just thought I'd put a list of all the extra bits you'll need to fit the box to your TD5. I reused some of the parts on the upgrade
so you'll need to buy
Gearbox cooler and pipe work
Auto flywheel
blanking foam for gearstick hole
Rubber boot to cover the foam
A D1 shifter or a cable for the D2 shifter
Centre console
Larger pedal and rubber to adapt the brake pedal
I think thats about it. All can be purchased from Aschrofts.
Post #879784 20th Jan 2021 6:48pm
J12Engineering
Dibs
PM sent👍
Post #880469 24th Jan 2021 9:07am
Walto70
Australia 2001 Defender 110 Td5 SW Chawton White
Hi Just wondering if you sold this stuff already?
Post #907004 9th Jun 2021 6:53am
TVR Tommy
Yes sold sorry
Post #907007 9th Jun 2021 6:55am
