Home > For Sale & Wanted > [For Sale] Defender auto conversion bits ZF4HP22 |
TVR Tommy Member Since: 26 Nov 2013 Location: Bucks Posts: 179 |
I've gone and pulled the hydraulic ZF4HP22 out of my defender to swap with a later electronically controlled box.
So I have 1X ZF4HP22 Hydraulic Box 1X TD5 bell housing Standard TD5 torque convertor and flex plate, spacer and bolts kickdown cable and mount where it comes through the firewall. I had to cut the kickdown bar off the pedal so will need reattaching Gearbox works fine selects all gears. I do have an invoice for a gearbox rebuild that was done on the box 20k miles ago. You'll need a shifter. I reused the Discovery 1 shifter. But I do have a D2 shifter but no cable to box for that. So if you fancy converting your TD5 to a cheap auto you can take the lot for £200 |
19th Jan 2021 3:35pm |
Just thought I'd put a list of all the extra bits you'll need to fit the box to your TD5. I reused some of the parts on the upgrade
so you'll need to buy Gearbox cooler and pipe work Auto flywheel blanking foam for gearstick hole Rubber boot to cover the foam A D1 shifter or a cable for the D2 shifter Centre console Larger pedal and rubber to adapt the brake pedal I think thats about it. All can be purchased from Aschrofts. |
20th Jan 2021 6:48pm |
J12Engineering Member Since: 06 Jun 2020 Location: Edge of the Cotswolds Posts: 30 |
PM sent👍
24th Jan 2021 9:07am |
Walto70 Member Since: 09 Jun 2021 Location: perth Posts: 1 |
Hi Just wondering if you sold this stuff already?
9th Jun 2021 6:53am |
Yes sold sorry
9th Jun 2021 6:55am |
