Home > Tdi > Oil level rising... |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Hi all,
well good news the alternator issues seem to have been sorted (for now) However on doing my pre-start I found that the oil was up near the danger mark. This is a bit of a shock as I had expected it to have dropped rather than raised having been stood. Coolant is clear and no signs of snot on the dipstick or oil filler, coolant not over-pressurising so I'm fairly happy its not that. However it does seem to be a bit down on power, was running a bit hot on test drive. The oil doesn't smell of diesel but its definitely not at the level I had previously run it at. Part of me is tempted to drain out the excess and run it for a day see where it ends up though I have a horrible feeling that could do a lot of damage. First thought is the lift pump leaking into the block and then sump, secondly the injectors. Any tests or checks I can do before I start buying parts? All the best Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
17th Jan 2021 8:59pm |
Exactly, which makes me think injectors or lift pump as there is nowhere else it could come from! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
17th Jan 2021 9:09pm |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 532 |
One thing you can check for diesel dilution. Dip dipstick put a drop of oil on some blotting paper. if only oil there you will have a full consistent circle. if diesel dilution in oil you will have a halo round the oil circle.
17th Jan 2021 9:24pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3376 |
we had a hairline crack in the head , enough to squirt diesel through under pressure Last edited by camelman on 17th Jan 2021 9:28pm. Edited 1 time in total |
17th Jan 2021 9:26pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2658 |
Diesel dilution on Tdis is not common like it is on Td5s.
I would change the oil and then monitor the level over a few hundred miles, see if it moves again. |
17th Jan 2021 9:27pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2248 |
Check the length of the dipstick tube. It is a common problem on Defender 200 Tdi, that because the fitting isn't secure, the tube can slide down dipping the dipstick deeper into the oil.
It should be 283mm from the top of the nut to the top of the tube. Any shorter and it'll be reading high. Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
17th Jan 2021 9:36pm |
Right, some quick tests done!
Dipstick measured the dipstick and its measuring 295mm from top of nut to top of tube which i have a dim and distant memory of doing this previously as it was loose and misreading. Click image to enlarge Needed all my extensions and a crows foot but got it tight Oil drip test completed Click image to enlarge 1st drop from the dipstick as removed, then the second was it cleaned, re-inserted and then dripped. I think it is showing no halo so the plot thickens? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
17th Jan 2021 10:54pm |
You've over filled it ?
18th Jan 2021 12:29pm |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 360 |
Oil will float on water, now let's assume that the water and oil didn't mix.
Loosen the sump plug and let a little bit out. It'll be a little messy but it will be another thing to tick off the list. |
18th Jan 2021 2:21pm |
Oil and water in an engine get well mixed and form an oily white emulsion which will be seen under the rocker cover through the oil filler.
18th Jan 2021 2:30pm |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 299 |
Sounds like it’s Engine oil and filter change time..
Ensuring you refill with 6.85 litres regardless of the dipstick. |
18th Jan 2021 2:48pm |
Yes , I've seen it enough times, that's why I said assume. Nothing surprises me anymore. |
18th Jan 2021 2:54pm |
I approached it from the wrong side. The question should be: Are you losing water?
18th Jan 2021 3:13pm |
Hi guys,
Just to update on this, no loss of coolant and no obvious routes of water ingress. Will drain, refill then keep an eye on it. Not the best time for this to happen as my other truck is going in for its MOT on Saturday Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
23rd Jan 2021 1:07pm |
