![]() | Home > My Defender > Santorini (formerly Java) Td5 90 |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10946 ![]() ![]() |
That's a bit odd ![]() Hope you get the issues sorted ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Good to hear with the issue fixing
![]() That's better, natural out side pic's, looking good ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 917 ![]() ![]() ![]() |
The big thing now is getting the VNT and mapping set-up by José (Td5INSIDE). Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
You will be rocking when he's worked his magic on the 90
He mapped it a few years ago, but I can’t wait to get this turbo singing! Charlie
102mm inlet and ducting fitted (after a small battle).
![]() Click image to enlarge ![]() Click image to enlarge Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
LT230 leak sorted. Turns out the input seal was the suspect. I can only assume it was damaged upon fitting, or was out of spec from the point of manufacture.
I noticed the heated screen wasn’t coming on a couple of weeks back, and found the tabs on the screen were broken. New screen and seal sorted that! Luckily, Venture 4x4 were able to fit the 90 in between their other work. I’m off to Wales on Friday, and didn’t want a screen that didn’t work and a leak that was not exactly minor. ![]() Click image to enlarge Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2940 ![]() ![]() |
Are you getting any wind noise from the light bar? Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Oddly enough, none whatsoever. My old Chinese one howled before I put some edge trim on this fins, but this is silent! Charlie
New Year Update
The LT230 is still leaking, despite changing the input seal. Rather annoying and disappointing. The tachometer has started to die, so I’ve had to order a new one from CAI. The engine oil leak has been fixed though! The oil filter housing had cracked catastrophically. A new housing and gasket has sorted it. ![]() Click image to enlarge ![]() Click image to enlarge Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Always good to stop the oil leak
