Home > Maintenance & Modifications > Remote Key
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Remote Key
Got myself a remote key, all in one, for Christmas.
Great service and easy to install and lightens the load in your pocket; it's almost like having a key for a real car!
I've gone from the clump on the right to the convenient key on the left.
Post #877769 11th Jan 2021 5:59pm
Hufflepuff
That looks neat Jools. Do you know where you got it from, other than Lapland? 2005 Td5 90 XS
1989 V8 110 CSW
Post #877771 11th Jan 2021 6:05pm
Alex L
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
I didn’t realise this was possible for that type of remote fob, I look forward to hearing where you got it from
Post #877800 11th Jan 2021 7:28pm
Ianh
I like the look of that key as well.
PS. I can’t see your fuel filler cap key on the new key ring, if its not under the new key don’t forget to put it on the new ring or you will have a sinking feeling when you go to fill her up with diesel Sad
Post #877810 11th Jan 2021 7:57pm
cold
Yes - interested also - looks a great mod 👍
Post #877811 11th Jan 2021 7:58pm
JoolsB
Well I got it from Father Christmas, but I have it on good authority that his supplier is
https://remotekey.co.uk/land-rover-keys-re...erallinone
Initially I was given the fob by mistake, but a call to them and the replacement was here in days - cut from my key number and works perfectly. very nice people to speak to on the phone.
It also has the added bonus of not falling out of the ignition barrel during a hard left turn - so apparently - they don't all do that!
TBH, I rarely lock the fuel filler so I generally leave the key in the glove box - I've got a startech on an optimill boss, but it's not convenient to take the steering wheel everywhere so I need to keep my steering lock key otherwise I'd be down to one.
Post #877932 12th Jan 2021 10:37am
JoolsB
Though I can't help wandering why my Range Rover (which is a year older) manages to do all of this with just one folding key, that's not an inconvenience at all - I mean, they obviously had those kind of bits available at the factory right?
Post #877934 12th Jan 2021 10:41am
dgardel
Italy
Razz
Old story here, was 2011
https://www.defender2.net/forum/topic7256.html
Over time I made three buying groups here in the forum Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #878095 12th Jan 2021 10:46pm
macfrank
nice, but "will work on all Land Rover Defender built from 1995 to 2012"
So my MY15 isn't old enough to have a modern set of keys Rolling Eyes - just saved £99.98 Very Happy
Post #878195 13th Jan 2021 12:19pm
Ianh
They do a version from 2012 to 2014 as well https://remotekey.co.uk/land-rover-defende...placement/
I thought the 2015 had a more modern integrated fob/ key anyway.
Post #878231 13th Jan 2021 2:28pm
macfrank
Unfortunately it's even fatter than the pre 2012 fobs. Sad
https://firstworldmotoring.files.wordpress...g_4068.jpg
To reduce the volume of our second set of keys, I've had a smaller key made recently:
The guy cutting the key was perplexed that there is no transponder in the key and asked if my car was an oldtimer Laughing In a way it is, I said. Laughing
Post #878248 13th Jan 2021 3:45pm
nicolas0505
France
Post #881597 28th Jan 2021 5:40pm
BADCADI
Switzerland 2010 Defender 110 Puma 2.4 CSW Alaska White
I enviously followed JoolsB's path and got one of those nifty single keys.
I can only echo that the service received was excellent. Sent in a picture of my present key and got a perfectly cut key in the mail. The programming was very simple and took less than 30 seconds.
A truly happy customer here, just in case anyone else is looking at this option.
Post #882657 2nd Feb 2021 3:14pm
HardCharger
Reviving this thread with a related question, when you programmed the all in one key, did you use their module to do it?
Does anyone know if we can use a GAP IIDTool BT unit to program their all in one keys?
Looking to getting one myself but don't fancy paying a lot for the module they rent you when I can program the standard FOBs using the IIDTool
Post #922554 24th Sep 2021 2:39am
fr123
2015 key fob
Hello, sorry this is my first post and I don't know if this is the correct place for it. I have a 2015 Defender with only 1 key fob. I have bought a replacement fob however have been told that it needs programming properly. Land Rover say they can't do it for the 2015/16 models. Any ideas would be greatly appreciated!
Post #1014567 9th Nov 2023 6:30pm
