![]() | Home > Puma (Tdci) > Traction Control kicking in too early. |
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 ![]() ![]() ![]() |
Check your diff lock lever isnt slipping (to the left) & engaging slightly, if will give a similar noise to traction control... Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3387 ![]() ![]() |
Has the vehicle got any mods / lift / suspension changes?
neil3728 Member Since: 18 Dec 2013 Location: Yorkshire Posts: 10 ![]() ![]() ![]() |
I'll have a look at that,
What confuses me more is that it only happens when turning right, never when I turn left. |
Only mods have been on for about 4 years, wheel spacers and slightly larger tyres 285's. thats it, rest is standard. |
astroarcadia Member Since: 12 Jun 2020 Location: Gloucestershire Posts: 49 ![]() |
I had this and it was the diff lock lever which had been knocked by the dog!
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
Is it a 2015 model with DSC?
If so: https://www.defender2.net/forum/topic75578.html?highlight=dsc ![]() ![]() |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
i have this with mine only at very low speeds in icy weather i do not brake heavy and after looking at the discussion's on here find it to be the the norm its my first experience of actually feeling the abs so aggressively not like any other car i have had
the defender has many odd traits this is one of them mine been a 90 is noticed more than a 110 luckily this fantastic forum helps me from going insane . thanks martin ![]() |
my 110 does it but that's got DSC a 2 inch lift and 35 inch tyres….
Mine is 2014 I don't believe this year had DSC. |
Had a look at the car this morning,
The Diff lock lever did move back across to the right as though it had been knocked, Although it did seem to reset itself back more neutral, will keep an eye on it hopefully it was just this thats causing a issue. Now to just find the weird knock from the passenger footwell, really need to get under the car but no time at the moment just a job to look at. |
Hopefully a fix! The Diff lever will normally move to a notch type neutral position but can sometimes creep over or get ever so slightly knocked etc, if its on the cusp of engaging it will give the effect you've experienced.
Good luck with the footwell! Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3481 ![]() ![]() ![]() |
Could it be tyre wear difference left to right or front to rear that triggers the TC turning to one side but not the other?
Typically tyres on the left wear more due to the right turns on roundabouts. When was tyre rotation done last? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
Mine was first registered in Sept. 2010 but is a 2011 Model Year vehicle. Land Rover seem to change specs. around the middle of the year and call the revised model the next years model year vehicle. So your 2014 could be a 2015 model. ![]() |
