Home > Puma (Tdci) > Traction Control kicking in too early.
neil3728
United Kingdom 2014 Defender 110 Puma 2.2 CSW Zambezi Silver
Hi slight strange one.
every now and again when traveling slowly and turning to the right, I get a noise like the traction control is kicking in and the light on the dash flashes. I have not notice it happen above 30mph.
Can happen even in the dry so its not the car slipping.
I'm not sure where to start looking, has anyone had a similar problem.
Many thanks in advance.
Neil
Post #876617 6th Jan 2021 12:32pm
Fat Cog
Check your diff lock lever isnt slipping (to the left) & engaging slightly, if will give a similar noise to traction control... Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #876620 6th Jan 2021 12:37pm
camelman
Has the vehicle got any mods / lift / suspension changes?
Post #876622 6th Jan 2021 12:38pm
neil3728
I'll have a look at that,
What confuses me more is that it only happens when turning right, never when I turn left.
Post #876623 6th Jan 2021 12:39pm
neil3728
Only mods have been on for about 4 years, wheel spacers and slightly larger tyres 285's. thats it, rest is standard.
Post #876625 6th Jan 2021 12:40pm
astroarcadia
I had this and it was the diff lock lever which had been knocked by the dog!
Post #876628 6th Jan 2021 12:46pm
Martin
Site Admin
Is it a 2015 model with DSC?
If so: https://www.defender2.net/forum/topic75578.html?highlight=dsc  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #876648 6th Jan 2021 1:31pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
i have this with mine only at very low speeds in icy weather i do not brake heavy and after looking at the discussion's on here find it to be the the norm its my first experience of actually feeling the abs so aggressively not like any other car i have had
the defender has many odd traits this is one of them mine been a 90 is noticed more than a 110
luckily this fantastic forum helps me from going insane . thanks martin Smile
Post #876661 6th Jan 2021 2:17pm
camelman
my 110 does it but that's got DSC a 2 inch lift and 35 inch tyres….
Post #876663 6th Jan 2021 2:21pm
neil3728
Mine is 2014 I don't believe this year had DSC.
Post #876669 6th Jan 2021 3:01pm
neil3728
Had a look at the car this morning,
The Diff lock lever did move back across to the right as though it had been knocked,
Although it did seem to reset itself back more neutral, will keep an eye on it hopefully it was just this thats causing a issue.
Now to just find the weird knock from the passenger footwell, really need to get under the car but no time at the moment just a job to look at.
Post #876827 7th Jan 2021 10:57am
Fat Cog
Hopefully a fix! The Diff lever will normally move to a notch type neutral position but can sometimes creep over or get ever so slightly knocked etc, if its on the cusp of engaging it will give the effect you've experienced.
Good luck with the footwell! Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #876830 7th Jan 2021 11:06am
Dinnu
Could it be tyre wear difference left to right or front to rear that triggers the TC turning to one side but not the other?
Typically tyres on the left wear more due to the right turns on roundabouts. When was tyre rotation done last? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #876836 7th Jan 2021 11:33am
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Mine was first registered in Sept. 2010 but is a 2011 Model Year vehicle.
Land Rover seem to change specs. around the middle of the year and call the revised model the next years model year vehicle.
So your 2014 could be a 2015 model.
Thumbs Up Just because you're offended doesn't mean you're right.
Post #876852 7th Jan 2021 1:25pm
