Home > In Car Electronics > Mudstuff double din dash install question |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1224 |
Basic answer is yes.
It depends which switches you have...and where you choose to position them. Some will reach, but if I recall correctly I extended the loom for 3 switches. Time consuming, but not difficult. Clemmo Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
5th Jan 2021 6:32pm |
siglo Member Since: 07 Aug 2015 Location: Kuwait Posts: 50 |
I have their kit and I did not have to extend the loom for any of the switches. I have a 2015 90 that's missing some switches (rear wiper switches, traction control, light leveling) so your mileage may vary.
Here's a photo of mudstuff's double din kit installed in my defender. The switch panel on the left side is from twisted. Click image to enlarge |
7th Jan 2021 6:56pm |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 685 |
Topic diversion.... Is that a checktemp in your dash? Got any closer photos of it? Looks great!
7th Jan 2021 7:09pm |
Yes it is. I found this old picture probably on the original fascia not on the double din. I used a dremel to cut out the hole where the head light leveling switch usually goes. The checktemp screen fits there almost perfectly.
7th Jan 2021 7:21pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6627 |
Quick and even easier now https://www.fnltd.co.uk/shop/defender-2002...-p124.html 1988 90 Td5 NAS soft top 2015 D90 XS SW |
7th Jan 2021 7:27pm |
Wow...expensive thou. Would make it easier.
Perfect if you don’t have the confidence or ability Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
7th Jan 2021 9:25pm |
Cheaper than hiring a auto electrician to extend your wires, or splattering solder on your dash plastics
Plug and play, job done in seconds. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
8th Jan 2021 11:20am |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 387 |
I made a few of these extender looms a couple of years ago using old modified switch bodies. Glad that someone has now manufactured the plugs for this. Really helped with my stereo install
Click image to enlarge 2015 90 XS Santorini Black |
9th Jan 2021 6:45pm |
Bish Member Since: 11 Nov 2008 Location: Hungerford Posts: 429 |
These are amazing and make the job so simple. You only really need to extend 1 loom if you are careful about which switches you move across. I just extend tithe rear heated windscreen from memory. |
10th Jan 2021 3:46pm |
Jungle1101 Member Since: 21 Feb 2021 Location: Glasgow, scotland Posts: 2 |
Hi, I was wondering if you could tell me how you extended your wiring? Did you use solder or connectors?, if connectors which type are best suited? I am in the process of doing this upgrade and will have to extend switches, I could probably get away with one but would like to do three as it will allow the cables to have some additional length and leave it a bit more tidy (I get no one will see it but I just think it's better to do it to a good standard). I don't have too much experience of this kind of thing so would appreciate any advice. |
21st Feb 2021 7:10pm |
Not precisely what you asked but the extension looms we sell now make this job very quick: https://fnltd.co.uk/shop/defender-2002-201...-p124.html 1988 90 Td5 NAS soft top
2015 D90 XS SW |
26th Feb 2021 9:53am |
