![]() | Home > Td5 > Self brake bleed |
Mini Landie Member Since: 23 Sep 2015 Location: Basingstoke Massiff Posts: 159 ![]() ![]() ![]() |
I have this model and it's a brilliant bit of kit. I've used Eezibleeds in the past and this is miles better. Biggest benefit is not having to lug a spare tyre about for air pressure!
I don't recall having any issues with the supplied bits and pieces, but I did use a bit of hose from my Eezibleed kit for the bleed nipple as the VS820 didn't come with one. Edit: I also have a TD5. |
Gozy Member Since: 02 Apr 2016 Location: Sidbury Posts: 43 ![]() ![]() ![]() |
Thanks Mini Landie. Your comments seem positive ,will hopefully have others to compare with also. Cheers
