Home > Td5 > Self brake bleed
Gozy
United Kingdom 2004 Defender 90 Td5 SW Aintree Green
Self brake bleed
Hi all. I am thinking purchasing the sealey VS 820 brake bleeding kit. Have read reviews some positive and others not so. Some found it to work well some have had leaks under pressure. Also does the cap supplied fit the expansion tank on the Td5. Thanks all Happy New Year. Gozy
Post #875680 1st Jan 2021 4:33pm
Mini Landie
United Kingdom 2003 Defender 90 Td5 HT Belize Green
I have this model and it's a brilliant bit of kit. I've used Eezibleeds in the past and this is miles better. Biggest benefit is not having to lug a spare tyre about for air pressure!
I don't recall having any issues with the supplied bits and pieces, but I did use a bit of hose from my Eezibleed kit for the bleed nipple as the VS820 didn't come with one.
Edit: I also have a TD5.
Post #875691 1st Jan 2021 5:31pm
Gozy
Thanks Mini Landie. Your comments seem positive ,will hopefully have others to compare with also. Cheers
Post #875696 1st Jan 2021 5:57pm
