Home > Modifications & Maintenance (L663) > Roof bar
Thino
United States
Roof bar
I’m looking for a very low roof bar (to mount a ski rack on). Did anyone find a good option already?
The Land Rover roof bar is likely too high (I’m
Parking in Manhattan garages)...
Post #875153 30th Dec 2020 2:00am
Defendit..
Netherlands
I'am working at the moment to modify the Thule Edge Wingbar 9595 ( M +L), the set 3040 sits in my opinion to high.
I want to bring it back to 2"
( If you have the roof rails..)
Post #875165 30th Dec 2020 9:10am
G4R1
Please keep us updated. I have the same thule set, but as you said it is too high Sad
Post #875271 30th Dec 2020 6:08pm
Defendit..
Netherlands
Did some DIY bracket work for the Thule. Did manage to bring the height back to 2"
Post #878316 13th Jan 2021 8:35pm
G4R1
That looks interesting, do you have any photos of them fitted to the car?
What I can from the photos you made a slightly smaller bracket and replaced the rubber “adapter” with thin layer of rubber or there are some other modification too? 3.0L MHVE D200 S Pangea Green+Black Pack
Adv. + Off-Road and Family Packs
Post #878337 13th Jan 2021 8:57pm
Defendit..
Netherlands
I made a new bracket, basicly the same size as the Thule. Drilled the 2 holes almost 9 or 10mm lower.
Sorry no pictures mounted, awaiting on my 90.
Next step when mounted is to shave the side covers so they will sit neat and look good.
Post #878352 13th Jan 2021 9:41pm
Defendit..
Netherlands
Work in progress..
some adjustments to make , wider mounting plates.
Can't get it lower for now
 No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #903699 18th May 2021 10:14am
Defendit..
Netherlands
Final result,
From rear
Cargorack in between
Post #906073 1st Jun 2021 11:55pm
G4R1
That’s looks great.
Do you have a photo of the final version of the bracket by any chance?
Did you have to trim the plastic cover? 3.0L MHVE D200 S Pangea Green+Black Pack
Post #906211 2nd Jun 2021 8:17pm
Defendit..
Netherlands
@G4R1
I will post a picture soon of the modified bracket, rubber, T-slot slider, 40 mm width with 8mm slotbolt
Only a very little trimming of the endcaps, managed to keep them almost original.
In the meantime I keep continuing modifiying my Bestop Cargo Rack with Scepter Fuel & Water and researching the mounting
possibility for Hi-Lift jack on the rear.
Front view
Side view
Top
Rear with Hi-Lift
Post #906266 3rd Jun 2021 7:10am
Essel
I'm looking to add a roof box and possible an awning to our new 90, we have already specced the roof rails. Obviously the Thule roof box goes with the Thule bars but can I also fit an awning onto these Thule bars? i'm looking at an ARB / Rhino-Rack Batwing Awning.
Post #908920 22nd Jun 2021 9:48am
