![]() | Home > Spotted > Two front differentials? |
Just when the new ones are loosing theirs...
![]() Click image to enlarge Tom Ford (@tomwookieford) Tweeted: Ok car nerds... first, identify why I got a bit obsessed with this. Second, try and figure out how the hell it would work! 🤔 #nichetweet #engineering #landrover https://t.co/u6cyJTGIrb https://twitter.com/tomwookieford/status/1339136140331413504?s=20 |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3524 ![]() ![]() ![]() |
That is what I thought.. a very early hybrid.. probably has a 'silent mode' button. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Twin rear diffs, too and a very busy engine bay, by the looks of it. As above, I'd also think early hybrid drive. Darren
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17697 ![]() ![]() ![]() |
I think it might be Landrover's attempt to create a perpetual motion machine, in which the front axle drives the rear axle which drives the front axle which drives ...
... well, you get the idea. I imagine that they rapidly realised the flaw with this, and that is why we don't all have them. |
At the same time it also looks very similar to the Tatra 4x4 system with dual crown and pinion setup per axle. Diff is further up the transmission tube.
If you look at the Defender pic, the way the diff pans are welded suggest that the pinions would rotate in opposite direction. Take a look at the Tatra setup: 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
I just came across a slightly better picture of this vehicle on Instagram and it turns out to be a NAS 90 with full roll cage. It is a prototype petrol electric hybrid.
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8205 ![]() ![]() ![]() |
Disco 2 outer axle case? Cheers
Yeah, either that or P38, depending when it was built I guess. Darren
