Home > Maintenance & Modifications > New USB product
Page 2 of 2 <12
kmac
Re: Usb
Helstoon wrote:
Where is the best place to find a supply for a USB behind the centre front panel?
Cigarette lighter would be the obvious choice, It is ignition switched.
Post #874474 23rd Dec 2020 11:30pm
Mo Murphy
... or more safely take a fused supply from the battery rather than piggy back off something else.
50 Shades of Pennine Grey
Post #874478 24th Dec 2020 2:29am
boode
England 2003 Defender 90 Td5 HT Rutland Red
[quote="hank"]Also available from Ian at IRB are these ones which also have a USB C... Bit more futureproof. quote]
Could someone please provide a link to this product - I cant find it on the IRB web site
I have installed the Mud USB socket and it looks good - but the switch is blacker thanmy other dash switches
But I would also like the USB C on the cubby so would also like this one from Ian
Post #874952 28th Dec 2020 6:49pm
hank
Send him an email Thumbs Up > 110 XS Double Cab
Post #874967 28th Dec 2020 8:40pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
If you can't get hold of Ian, I bought mine from Germany. I can't remember from whom because it was ages back but it's called a Power Double USB-C/A Socket.
EDIT
https://www.pro-car.de/en/products/usb-a-u...n-sockets/ WARNING.
This post may contain sarcasm.
Post #874969 28th Dec 2020 9:06pm
If you want a plug and play supply I would use one of these on the lighter socket ATO fuse in the panel.
https://www.ebay.co.uk/itm/153500441906
The access panel will close just, you can reduce the lighter supply fuse rating by 5A and fit a 1A ATO for the USB socket.
That will still give you 15A current rating on the lighter supply if memory serves me rightly.
There are some fixings around the bonnet opening mech (drivers footwell) you could use as a grounding point.
It’s only a low load so should be fine. Again relatively easy accessible.
I think they are M6 with flanged nuts but don’t quote me on that as a fact. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #874974 28th Dec 2020 9:30pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Re: Usb
I tapped mine from the hazard feed because I wanted the USB sockets to be live at all times. It is also worth noting that the illumination on the Mud USB sockets is waaay too bright compared with the original LR switches. To fix this I inserted a 200K resistor into the illumination +ve for each socket. See pic (just before it was encased in heatshrink):
The resistor dimmed it to an acceptable level:
Post #882210 31st Jan 2021 5:33pm
boode
I need to do the same with a resistor - what a brilliant idea
Just googles 200k resistors - is the Wattage important ? - some are rated 2w others 0.4w
Any advice for a non electrition
Post #882232 31st Jan 2021 7:02pm
Intercept
Just googles 200k resistors - is the Wattage important ? - some are rated 2w others 0.4w. Any advice for a non electrician
This is a very low current application so you'll be fine with a 0.25w or 0.4w. I'm not sure what my resistors' ratings are but they'll be in that vicinity judging by their size. Higher wattage would also be fine - just physically bigger.
Post #882239 31st Jan 2021 7:29pm
JOW240725
90 Dreamer wrote:
do you have a link or pic please??
here.... https://www.defender2.net/forum/topic49880.html?highlight=switch
 James
Instagram @suffolk_rovers
Post #882244 31st Jan 2021 7:53pm
Page 2 of 2 <12
