Home > Puma (Tdci) > Battery terminal clamp - how does it work
RichLech
United Kingdom 2012 Defender 90 Puma 2.2 HT Keswick Green
The picture shows the negative battery terminal on my 2012 Defender. I can't make out how the clamp is tightened onto the terminal. The nut on top of the the clamp is as tight as it wants to go but the clamp can still be turned by hand on the terminal. I wouldn't say it is loose but it does move. I thought it should be tighter than that.
Any thoughts? Am I missing something obvious? Is it the nut on top that provides the clamping action, and if so, how?
Post #872435 11th Dec 2020 3:37pm
Bluest
The nut should tighten the clamp. It has probably been overtightened and crushed the battery terminal so it no longer grips. You could try packing it out by wrapping some strips of flat copper around the terminal.
Or, you could replace it for a conventional clamp with a pinch bolt which should go tighter.
Or you could buy a new battery Thumbs Up 2007 110 TDCi Station Wagon XS
Post #872444 11th Dec 2020 4:14pm
Dinnu
Battery post is tapered, so try pushing the terminal down as much as possible before tightening the nut. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #872447 11th Dec 2020 4:27pm
I added a small sliver of copper sheet to mine - works a treat:
More details here:
https://www.defender2.net/forum/post716692.html#716692 Darren
Post #872457 11th Dec 2020 5:17pm
There is a split conical section on the terminal below the nut, and an inverted conical sleeve immediately under the nut. Tightening the nut pushes the conical sleeve down the split taper in theory pulling the terminal tight on the battery post.
Unfortunately they are over-engineered, ineffective, and complex, and as you have found really don't work well at all. My personal preference is to replace them with the type below, but I have the advantage of owning professional crimping tools for almost ever size.
Post #872465 11th Dec 2020 5:41pm
RichLech
Many thanks. I've ordered some copper sheet in case I cannot tighten it without.
Post #872528 11th Dec 2020 10:08pm
jst
you can be really low tech and put a wood screw between terminal and clamp if in 'need to get home scenerio' Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #872697 13th Dec 2020 10:57am
topless_matt
Have used a strip of a coke can in an emergency Hold my beer and watch this!
Post #873787 19th Dec 2020 7:47pm
