![]() | Home > Puma (Tdci) > Battery terminal clamp - how does it work |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4261 ![]() ![]() ![]() |
The nut should tighten the clamp. It has probably been overtightened and crushed the battery terminal so it no longer grips. You could try packing it out by wrapping some strips of flat copper around the terminal.
Or, you could replace it for a conventional clamp with a pinch bolt which should go tighter. Or you could buy a new battery ![]() |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3535 ![]() ![]() ![]() |
Battery post is tapered, so try pushing the terminal down as much as possible before tightening the nut. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
I added a small sliver of copper sheet to mine - works a treat:
![]() Click image to enlarge More details here: https://www.defender2.net/forum/post716692.html#716692 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17718 ![]() ![]() ![]() |
There is a split conical section on the terminal below the nut, and an inverted conical sleeve immediately under the nut. Tightening the nut pushes the conical sleeve down the split taper in theory pulling the terminal tight on the battery post.
Unfortunately they are over-engineered, ineffective, and complex, and as you have found really don't work well at all. My personal preference is to replace them with the type below, but I have the advantage of owning professional crimping tools for almost ever size. ![]() |
RichLech Member Since: 09 Nov 2015 Location: West Sussex Posts: 115 ![]() ![]() ![]() |
Many thanks. I've ordered some copper sheet in case I cannot tighten it without.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8217 ![]() ![]() ![]() |
you can be really low tech and put a wood screw between terminal and clamp if in 'need to get home scenerio' Cheers
topless_matt Member Since: 29 Mar 2015 Location: norfolk Posts: 68 ![]() ![]() ![]() |
Have used a strip of a coke can in an emergency Hold my beer and watch this!
