Home > In Car Electronics > High beam woes |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10751 |
The first thing that comes to mind is the hazard lights switch, but i'm no mechanic/electrician. 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
11th Dec 2020 8:21pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
Me neither
However, my powers of observation have led me to believe the culprit might be this; Click image to enlarge Click image to enlarge Can anyone with some elastictricky knowledge point me in the direction of replacing the now defunct relays? The loom is a Landreiziger , however I cannot find the relays alone on their website Cheers |
9th Jan 2021 2:20pm |
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 |
What age ?
9th Jan 2021 3:11pm |
Loom is about 2 years and I’m 46 thank you for asking
9th Jan 2021 3:31pm |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 529 |
Are there not numbers on the base to identify from, other than the terminal numbers?
9th Jan 2021 3:57pm |
The plug in bases look like those that you'd use with a standard 30amp relay. Darren
9th Jan 2021 4:12pm |
I got a close up picture of the base...the pins are bent so you can see the numbers
Click image to enlarge Going clockwise from the top the numbers are ; 85-36-86-87 Thanks |
9th Jan 2021 5:24pm |
It's likely 30 rather than 36 and it matches a standard relay:
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
9th Jan 2021 5:39pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17377 |
They should be bog standard relays, widely available. Just check (as LRA says) the pin numbers, these are SAE standard and will confirm the correct part.
9th Jan 2021 5:50pm |
Excellent, thanks all
I shall get some ordered |
9th Jan 2021 6:01pm |
HELLA Relay Socket 8JD745801-011
HELLA 007794301 Cover with Weatherproof Mini ISO Relay Last edited by dorsetsmith on 10th Jan 2021 1:02pm. Edited 1 time in total |
9th Jan 2021 7:48pm |
i found Halfords do them, i shall pop down tomorrow and pick up a couple
https://www.halfords.com/tools/fuses-elect...84005.html |
9th Jan 2021 10:52pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2039 |
Have our been wading a little to deep then Badger110 ?
10th Jan 2021 11:11am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
https://www.12voltplanet.co.uk/twin-make-b...b3EALw_wcB 02' 110 TD5 Double Cab Rebuild Thread
10th Jan 2021 12:19pm |
