Home > Maintenance & Modifications > Middle Row Seats Upgrade (TD5 110)
steve_c3
United Kingdom 2002 Defender 110 Td5 SW Epsom Green
I have a 52 plate TD5 110 with the low back 60/40 split rear seats. My little ones have grown out of their car seats and I need to fit some high backs. I think I have two options:
1. Fit some Exmoor Trim Premium High backs. I can see a few members have and they look great but but are a bit out of my price range a the moment.
OR
2. Is it easy enough (and has anyone done it?) to fit some early defender seat bases that allow all three to fold and fit the Exmoor Trim Classics at £450 for three? Looking at what I've got, I may only need to add the brackets for the additional split section rather than replacing all the brackets? 2002 Defender 110 CSW TD5
Post #869508 25th Nov 2020 9:28am
No.2 is easy enough to do but finding the bases may be a challenge. Darren
Post #869519 25th Nov 2020 10:06am
landroverdiver
I did option 2. It was easy enough, the frames are difficult to get hold of, but you do need to factor in the additional cost of catches, nuts, bolts etc. You be amazed how quickly this adds significant cost to the option. Probably worthwhile checking the cost of all the parts to enable a proper comparison of options.
I used 2 high backs and 1 low back, which look very good. I am reliably informed however that the end result is not very comfortable for long journeys.
Hope this helps
Post #869546 25th Nov 2020 2:25pm
bankz5152
The old style 60/40 Exmoors are VERY uncomfortable.
If you can weld...
2018 Range Rover Sport seats in a DCPU, headroom is a little low but legroom improved.
 Instagram @defender_ventures
Empire Tuning - Agent
Post #869555 25th Nov 2020 3:08pm
steve_c3
Thanks for the info all. I think the comfort might be a factor then - if I'm going to do it, I probably need to make sure there's no reason for any more complaints from the back seat passengers!
bankz5152 - those seats look awesome - although I think they be too much of a squeeze in mine as I have an internal hoop on my cage to contend with as well!
After googling some more pics, the Premiums look like they may be the better option - will have to see how deep Santas pockets are this year Whistle 2002 Defender 110 CSW TD5
Post #869561 25th Nov 2020 3:42pm
Court Jester
2003 Defender 90 Td5 HT Bonatti Grey
Those seats look amazing! How easy are they to fit to a TD5 please? Can the frame be modified safely or (like with Puma seats ) do you need extensive chassis mods?
Post #895472 1st Apr 2021 10:57pm
