![]() | Home > Maintenance & Modifications > Middle Row Seats Upgrade (TD5 110) |
No.2 is easy enough to do but finding the bases may be a challenge. Darren
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 ![]() ![]() |
I did option 2. It was easy enough, the frames are difficult to get hold of, but you do need to factor in the additional cost of catches, nuts, bolts etc. You be amazed how quickly this adds significant cost to the option. Probably worthwhile checking the cost of all the parts to enable a proper comparison of options.
I used 2 high backs and 1 low back, which look very good. I am reliably informed however that the end result is not very comfortable for long journeys. Hope this helps |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2206 ![]() ![]() ![]() |
![]() Click image to enlarge The old style 60/40 Exmoors are VERY uncomfortable. If you can weld... 2018 Range Rover Sport seats in a DCPU, headroom is a little low but legroom improved. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
steve_c3 Member Since: 30 Apr 2015 Location: Hants Posts: 177 ![]() ![]() ![]() |
Thanks for the info all. I think the comfort might be a factor then - if I'm going to do it, I probably need to make sure there's no reason for any more complaints from the back seat passengers!
bankz5152 - those seats look awesome - although I think they be too much of a squeeze in mine as I have an internal hoop on my cage to contend with as well! After googling some more pics, the Premiums look like they may be the better option - will have to see how deep Santas pockets are this year ![]() |
Court Jester Member Since: 12 Aug 2018 Location: North Devon Posts: 5 ![]() ![]() |
Those seats look amazing! How easy are they to fit to a TD5 please? Can the frame be modified safely or (like with Puma seats ) do you need extensive chassis mods?
